Help Headlight bulb 9006 keeps blowing
Old Apr 21, 2006 | 02:18 PM
badbeast's Avatar
Default Help Headlight bulb 9006 keeps blowing
Let me know guys? Its the same side low beam on drivers side. Its blowed 4 times! All fuses are good Its on a 01 Accord Coupe
Old Apr 21, 2006 | 02:21 PM
MilanoLude's Avatar
Default Re: Help Headlight bulb 9006 keeps blowing (badbeast)
Are you touching the bulbs with your hands when you replace them?
Old Apr 21, 2006 | 03:11 PM
iam7head's Avatar
Default Re: Help Headlight bulb 9006 keeps blowing (MilanoLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MilanoLude &raquo;</TD></TR><TR><TD CLASS="quote">Are you touching the bulbs with your hands when you replace them?</TD></TR></TABLE>
oil in finger or the higher wattage aftermarket bulb
Old Apr 21, 2006 | 03:57 PM
philadd's Avatar
Pull the connector off and look at the terminals. I'm betting the ground one is burnt/corroded/shot.
Old Apr 21, 2006 | 04:04 PM
YeuEmMaiMai's Avatar
Default Re: Help Headlight bulb 9006 keeps blowing (philadd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philadd &raquo;</TD></TR><TR><TD CLASS="quote">Pull the connector off and look at the terminals. I'm betting the ground one is burnt/corroded/shot.</TD></TR></TABLE>
That would definately do it...........
Old Apr 21, 2006 | 09:12 PM
badbeast's Avatar
Default Re: Help Headlight bulb 9006 keeps blowing (iam7head)
Yes I think ,I need a higher wattage
Old Apr 22, 2006 | 02:28 AM
you do not need higher wattage you need to clean the connectors and make sure they are making good contact with the bulb
Old Apr 22, 2006 | 07:36 AM
iam7head's Avatar
Default Re: Help Headlight bulb 9006 keeps blowing (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">you do not need higher wattage you need to clean the connectors and make sure they are making good contact with the bulb</TD></TR></TABLE>
ditto
serious people think they can just use higher wattage bulb. the harness is design to run a certain wattage(oem spec), anything higher would neither the blub burns out or the harness melts.
Old Apr 22, 2006 | 08:43 AM
Ross 2.0's Avatar
In a Junkyard near you.
If you are sure that you arent touching the glass then you should check your alternator output. It may be too high thus cooking the bulb (and other components) Get a multi-meter and check battery voltage with the car running.
Old Apr 22, 2006 | 10:41 AM
badbeast's Avatar
Default Re: (MooGoCow3)
tHANKS gUYS
young noob
14
Aug 31, 2006 02:25 PM
91accordwagon
Aug 28, 2006 11:14 AM
Cdn01ITR
Dec 25, 2005 06:56 PM
Dc2 Powered
Aug 7, 2004 12:11 AM
SyDuck
Aug 4, 2004 05:36 PM
