tire sizes?
Old Apr 21, 2006 | 01:31 PM
alex_s817's Avatar
Default tire sizes?
what would be the best tires for 16x7.5 inch wheels ? right now i am running those wheels with 205/55/16 tires and they rub terribly. i have ground controls on stock shocks and i raised them up as far as they could go and they still rub. mainly on the back but some on the front too. i dont know what to do. should i just get 205/45/16? or could i fit a 195/45/16 on these wheels? i want to be able to lower the car back down if at all possible. thanks for all the responses
Old Apr 21, 2006 | 01:39 PM
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
Default Re: tire sizes? (alex_s817)
Keep the width the same 205 is fine... i would recommend a smaller profile though. At least a 205/50/16 if not smaller. Good luck
Old Apr 21, 2006 | 01:44 PM
.brian.'s Avatar
Default Re: tire sizes? (ForceFed_Motorsports)
you should be fine with 205/45/16
Old Apr 21, 2006 | 01:49 PM
alex_s817's Avatar
Default Re: tire sizes? (.brian.)
the little lip that comes off of the fender always rubs the top of my tire. it does now, even with the GCs adjusted all the way up. i know getting a smaller tire will help to not rub, being at the height i am now. but say i want to lower my car back down, so there is no gap between the tire and wheel, would it rub then? i asked about the 195 because i figured it would tuck up inside the wheel well, missing the fender's lip. are 7.5 wide wheels to wide for 195s? thanks a lot
Old Apr 21, 2006 | 01:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alex_s817 &raquo;</TD></TR><TR><TD CLASS="quote">the little lip that comes off of the fender always rubs the top of my tire.</TD></TR></TABLE>
Me too lol... i have no idea why (sarcasm, sorry). Smaller tires and wheels are the answer if you dont want any rubbing. 205/45/16 would be my choice with 16's.
Old Apr 21, 2006 | 02:03 PM
alex_s817's Avatar
how much of a difference is there between 195/45/16 tires and 205/45/16s? j/w how low is your car ? (inches from stock)
Old Apr 21, 2006 | 02:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alex_s817 &raquo;</TD></TR><TR><TD CLASS="quote">how much of a difference is there between 195/45/16 tires and 205/45/16s? j/w how low is your car?</TD></TR></TABLE>
I have 195/60/15's which was a screw up in the first place. But 205's will look better than a 195, notice how mine arent flat along the rim but more rounded...looks gay.
I have a 3.25 inch drop, i had it lower but under hard acceleration my tires were rubbing like mad... and they still do quite a bit. I have adjustable Skunk2 suspension so i can just raise or lower it as i please.
No doubt about it 205/45/16 is what you want... heres a pic of a local dude with a 215/45/16 setup for SCCA autocross (not taking credit, and yes i know he was in import tuner to all those haters reading this)
Old Apr 21, 2006 | 02:20 PM
alex_s817's Avatar
ok so 205/45/16 is what ill go with, what is your addvice on the rubbing? should i get the rear fenders rolled? or just leave it
Old Apr 21, 2006 | 02:23 PM
I guess it depends on how low you go... ive seen people nearly on the ground not have too many problems. I would get the tires and then see. Good luck
Im leavin rite now to go pick up some new tires... i hate mine more now that i look at them closely. Ill post up picks with my new blades and tires, later.
Old Apr 21, 2006 | 02:27 PM
alex_s817's Avatar
alright thanks for all the help man, make sure u post those pics!
Old Apr 21, 2006 | 04:50 PM
slowly slipping away's Avatar
i ran a similar setup (like yours) for years... 205/45/16 is a good size, worked great! I did however step it up to a 215/40/16 (like the guy in the pic..yea I know that kid!)
Old Apr 21, 2006 | 04:55 PM
alex_s817's Avatar
Default Re: tire sizes? (dtdub)
how much wider are the 215/40/16s ??
Old Apr 21, 2006 | 07:14 PM
not much at all considering it is only a size off just makes them a little more flush with the fenders..if you really want them "tucked" go with the 205's also forgot to mention, if its in the budget a new set of performance shocks would do you well, do the tires rub over bumps? could be due to the stock shocks (If I read that right- long day) Tokico HP's might be a good start
Old Apr 21, 2006 | 07:16 PM
..oh sorry forgot to add- stick to a 40 or 45 series tire
Old Apr 22, 2006 | 10:41 PM
alex_s817's Avatar
Default Re: tire sizes? (slowly slipping away)
oh yea, oi plan on getting some koni yellows to go with the GCs but right know my tires rub on every little bump. do you know how much smaller overall they will be with the 205/45/16 over the 205/55/16?
Old Apr 22, 2006 | 11:43 PM
alex_s817's Avatar
no one has help?
Old Apr 23, 2006 | 09:58 AM
Not sure exact measurements but it will be a substantial difference...maybe a half inch or more.
Old Apr 24, 2006 | 03:53 AM
teggsr925's Avatar
205/45/16 or 205/50/16 .....i had 205/55/15 on my blades at stock ride height and u have bigger rims with a drop
Old Apr 24, 2006 | 05:50 AM
Robstunner4's Avatar
Default Re: tire sizes? (teggsr925)
i have 205/45/16 on my car now.
im on HR sports and when i had 205/50/16 they rubbed at turns and also at good bumps in the road. (rubbign like tire hitting fender)
they were 205.50.16 goodyear eagle f1's
definatley go with 45 series.
midori_rivas
Sep 8, 2014 07:17 PM
JD95hatch
Aug 20, 2004 02:07 PM
Grip
Apr 18, 2004 12:47 AM
ebelp
Feb 6, 2003 09:05 AM
vtecdc2
Sep 22, 2002 08:15 AM
