blue smoke during deceleration
Old Apr 21, 2006 | 01:18 PM
blacK_Dc4's Avatar
Default blue smoke during deceleration
hey .. i have a 95 gsr .. i have blue smoke coming out from the exhaust when shifting gears , deceleration , but normal white smoke during idle .. i understand that i am burning oil ..about 1 to 1.5 quarts per 3000 miles .. but i would still like to fix the problem ... any ideas where to begin ?
Old Apr 21, 2006 | 03:04 PM
auslander's Avatar
Default Re: blue smoke during deceleration (blacK_Dc4)
If your piston rings are in good shape, then it sounds like your valve stem seals are seeping.
If you downshift instead of just pushing in the clutch and letting the engine idle as you slow down it will suck in a lot of oil if the seals aren't good. My '91 is really bad about that. If I downshift, I'll go through a quart every 2k mi, if I don't it's more like .5 qt every 4k mi.
Old Apr 21, 2006 | 03:05 PM
2000GSR2432's Avatar
Thats not a whole lot of oil being burnt to where I would worry a whole lot, it sounds to me that it may be your valve seals. My car burns the same amount as well, was told it was my valve seals from a tech. Compression test turned out good mid 190's across the board. I wouldnt worry bout the rings, but u might want to have a compression and leakdown test.
Old Apr 21, 2006 | 07:57 PM
blacK_Dc4's Avatar
Default Re: blue smoke during deceleration (2000GSR2432)
o ok thank you .. its a relief to kno its most likely not the rings .. bump for more
Old Apr 22, 2006 | 01:13 PM
blacK_Dc4's Avatar
is changing the valve seals a simple job or does it require takin off the head ?
Old Apr 22, 2006 | 06:48 PM
s2kdre's Avatar
its better to take the head off cause u wanna make sure the valve guides are good too, cause u can leak iol through those too.
Old Apr 22, 2006 | 07:19 PM
Vtecme92's Avatar
Default Re: blue smoke during deceleration (jdmhonda)
did you have any oil leaking into your pistons or in to your cylinders? I have a similar problem but there is some kind of liquid in my 2 and 4th cylinder cause my spark plug is wet?
Old Apr 22, 2006 | 07:59 PM
blacK_Dc4's Avatar
Default Re: blue smoke during deceleration (Vtecme92)
uhh .. i dont kno about all that but my spark plugs for sure is dry
Old Apr 22, 2006 | 08:12 PM
CleanLikeJdm's Avatar
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtecme92 &raquo;</TD></TR><TR><TD CLASS="quote">did you have any oil leaking into your pistons or in to your cylinders? I have a similar problem but there is some kind of liquid in my 2 and 4th cylinder cause my spark plug is wet?</TD></TR></TABLE>
You probably just have bad gaskets for the sparkplug holes from the valvecover gasket set.
Ha, and only one quart really isn't that bad, I could go through 4-5 before an oil change, 4k and up it would leave clouds of smoke.
Valve seals are the first thing to go for though, which almost sounds like the problem.
Old Apr 23, 2006 | 07:22 PM
blacK_Dc4's Avatar
Default Re: blue smoke during deceleration (FlatBlackTeg)
wow .. thats a lot .. its blue smoke that comes out of ur muffler too ?
Old Apr 25, 2006 | 01:26 AM
blacK_Dc4's Avatar
hmm .. now that i look at it more .. it has a lot of blue smoke when i WOT also .. is this still an indication of bad valve seals or something else ?
dvd5904
74
Apr 5, 2010 05:49 AM
prettylew
45
Dec 16, 2007 06:48 PM
HybridBB6
May 14, 2007 02:36 PM
codyb13
Jun 16, 2005 08:47 AM
tianporn
10
Jul 20, 2004 11:24 AM
