high compression with JRSC
Old Apr 21, 2006 | 11:40 AM
Speed Infliction's Avatar
Default high compression with JRSC
would it be ok to run 12.5:1 compression with Jun 3's on pump gas with a jackson racing supercharger? let me know whats up so i dont blow my motor.
Old Apr 21, 2006 | 08:10 PM
WrongWD's Avatar
the supercharger will be absolutely useless with those cams
Old Apr 21, 2006 | 08:17 PM
0IOI0's Avatar
Default Re: high compression with JRSC (Fayzeless)
high compression is ok... just needs to be tuned very well...
but as for the cams..you'll be better off with a turbo cam....
Old Apr 21, 2006 | 11:31 PM
Default Re: high compression with JRSC (0IOI0)
wow! I didn't know that you can run 12.5:1 compression with a supercharger! That is crazy! Would it be a reliable motor and can it run on pump gas?
Old Apr 22, 2006 | 10:56 AM
WrongWD's Avatar
youd hafta run reallllllly low boost.... and whats the highest octane you can get there?
Old Apr 22, 2006 | 10:08 PM
jdmhondacrx's Avatar
Default Re: (WrongWD)
not possible my home boi has a high compression lsv 11.8 to 1 and no matterhow the tune was it started to ping at 6 000 rpms and it was tuned by shawn church. oo he took off the supercharger and made 221 horse power wit blox 3
Old Apr 23, 2006 | 06:29 AM
sc4dr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fayzeless &raquo;</TD></TR><TR><TD CLASS="quote">would it be ok to run 12.5:1 compression with Jun 3's on pump gas with a jackson racing supercharger? let me know whats up so i dont blow my motor.</TD></TR></TABLE>
Do you already have that motor setup? It is soooo not what you want for a jrsc app. I'm running 9.2:1 compression, w/ gsr in. cam, and itr ex. cam, and 15 psi. Oh yeah, and pump gas. This setup is just more reliable, and w/ over 240 ft lbs. @ 3,500 rpm...hold on.
Old Apr 23, 2006 | 03:13 PM
mmuller's Avatar
Mad Scientist
Default Re: high compression with JRSC (sc4dr)
different cams and if you attempt to supercharge intercooling is a must.
jrsc's heat up air a LOT
queda
Oct 11, 2007 08:49 AM
Speed Infliction
Apr 21, 2006 12:06 PM
spoonEGcivichatch
Sep 18, 2005 09:51 AM
Rice Is Best
12
Dec 29, 2004 10:29 AM
GRTechnologies
Aug 11, 2003 07:20 AM
