Crower cams & passing EPA
Old Apr 21, 2006 | 11:30 AM
WJHMH's Avatar
Default Crower cams & passing EPA
I'm thinking about adding some Crower non-vtec stage 2 cams to my LS Integra but I'm concerned that I may not be able to pass emissions test. Has anyone had this problem before?
Thanks.
Old Apr 21, 2006 | 12:45 PM
Scott_Tucker's Avatar
Default Re: Crower cams & passing EPA (WJHMH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WJHMH &raquo;</TD></TR><TR><TD CLASS="quote">I'm thinking about adding some Crower non-vtec stage 2 cams to my LS Integra but I'm concerned that I may not be able to pass emissions test. Has anyone had this problem before?
Thanks.
Are you saying the car is not vtec or the cams lock out the low speed cam lobes on the vtec? Either way there are a lot of variables that go into what will be ejected out the exhaust pipe. Tuning of fuel and spark being the most important. What do they test for in TX? Do they use a dyno (well, it's a rolling road actually)? If they measure NOx and you are using a cam that has more overlap than stock you possibly may be better off because at low speeds the overlap will allow exhaust gas 'reversion' and dilute the intake charge just like an EGR valve does. Make sure your cat is in good condition.
fungus mungus
Jun 11, 2012 08:26 PM
judd_123
Sep 3, 2010 06:54 PM
dohc_profile
Nov 13, 2007 08:32 AM
joey funk
12
Sep 16, 2007 12:16 PM
drSquish
Jun 20, 2006 12:11 PM
