Need help with Autometer wiring install into 97 h22 teg
Old Apr 21, 2006 | 11:24 AM
2.2 teg's Avatar
Default Need help with Autometer wiring install into 97 h22 teg
I have 3 Autometer gauges I need help with the wires.
On the A/F gauge there are 4 wires- White, Red, Purple, and Black.
Where do all of these go? I know the White one goes to the pinout on the ECU, but what about the others?
On the Water gauge there are 3 Blue wires, and 1 Black and 1 White wire.
Was thinking about hooking this up to the ECT (Engine Coolent Temp) Sensor, but dont know which wires go where.
On the Oil Pressure gauge there are also, 3 Blue wires, and 1 Black and 1 White wire. On the round reciver that goes on the back of the block there is only one end comming off of it.
The Water and Oil gauges are both mechanical. All three gauges are the Lunar series. Thanks for the help.
Old Apr 21, 2006 | 01:43 PM
2.2 teg's Avatar
Default Re: Need help with Autometer wiring install into 97 h22 teg (importtunerboy)
Old Apr 22, 2006 | 09:31 AM
2.2 teg's Avatar
bump
Old Apr 23, 2006 | 07:57 PM
2.2 teg's Avatar
come on, i know there are ppl out there with these gauges!
Old Apr 25, 2006 | 10:44 AM
2.2 teg's Avatar
Old Apr 26, 2006 | 08:24 PM
2.2 teg's Avatar
Old Apr 28, 2006 | 02:05 PM
H24A96EK's Avatar
don't know bout the lunar's but the sport comps white and black were for the lighting which isn't hard to figure out but the lighting on yours has got to be different. post a pic. i am actually interested in seeing the backs of them. what is special lighting wise with these compared to the regular guages.
Old May 4, 2006 | 08:57 PM
2.2 teg's Avatar
Default Re: Need help with Autometer wiring install into 97 h22 teg (Duce_Duce Teg)
Ok here are the pics let me know if you can help
A/F Gauge
Oil Pressure gauge: Notice: 3 blue wires and the 1White and 1Black wire
Sender Unit
Water Temp. Gauge :Notice: Wire set-up same as oil pressure gauge
There you go H-T, I need some help.
Old May 5, 2006 | 07:22 AM
2.2 teg's Avatar
Old May 5, 2006 | 08:24 AM
devnull's Avatar
First off if you had gone to http://www.autometer.com and clicked on install help you'd have this done already.
A/f:
Red - power
Black - ground
white - LIGHTS ON
Purple - White wire on O2
Oil Pressure:
White - LIGHTS ON
black - ground
From left to right accoring to your picture as posted.
left Signal - Goes to Autometer Oil pressure sending unit
middle is ground, right is power (ignition on)
Water Temp:
Same as Oil.
Old May 5, 2006 | 09:05 AM
2.2 teg's Avatar
Default Re: (devnull)
i have gone there but sometimes the site is down or i cant download the files, but thanks anyways
gmbdelsol
Apr 10, 2011 12:46 PM
1sickek187
Dec 7, 2008 04:55 PM
2.2 teg
Apr 26, 2006 08:23 PM
2.2 teg
Apr 25, 2006 11:03 AM
Civicdrgrcr
Sep 15, 2002 10:35 PM
