special socket for flywheel bolts?
Old Apr 21, 2006 | 08:49 AM
92integraVTECgsr's Avatar
Default special socket for flywheel bolts?
im about to change my clutch and flywheel and just wanted to know if i needed a special socket to remove the flywheel bolts?
or is it just a regular 10mm 12 point socket?
Old Apr 21, 2006 | 09:19 AM
gsrjrsc's Avatar
Default Re: special socket for flywheel bolts? (92integraVTECgsr)
ive put a 12pt socket on there and it fit pretty tight and it seemed like it would work but i havent removed the fly wheel because im kinda thinking what your thinking too
Old Apr 21, 2006 | 09:40 AM
gsrious's Avatar
correct sized 12pt socket will work just fine, as the bolt was designed to use a 12pt socket.
Old Apr 21, 2006 | 09:48 AM
ImportMotorSpec's Avatar
Default Re: (gsrious)
The pressure plate bolts are 10mm socket 12 pt. and the flywheel bolts are 17mm socket 12 pt. I have taken over 30 off and never had a problem.
Old Apr 21, 2006 | 12:25 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr &raquo;</TD></TR><TR><TD CLASS="quote">im about to change my clutch and flywheel and just wanted to know if i needed a special socket to remove the flywheel bolts?
or is it just a regular 10mm 12 point socket?</TD></TR></TABLE>
the flywheel bolts are 12 point 17mm and the clutch(pressure plate) bolts are 12-points 10mm
Old Apr 21, 2006 | 12:28 PM
typer_696's Avatar
Default Re: special socket for flywheel bolts? (projectTeG)
No special tool just a 12pt socket to insure grip and not strip. You will need something to hold the flywheel so it dont spin on you.
Old Apr 21, 2006 | 12:34 PM
Lan's Avatar
Lan
12 pt. 10mm and an impact gun. Take them off in a criss cross pattern. I am almost positive you want to put locktite on the threads when re-installing them.
Old Apr 21, 2006 | 02:59 PM
robTypeGs-R's Avatar
Default Re: special socket for flywheel bolts? (Lan)
negative
Old Apr 21, 2006 | 03:00 PM
92integra-R's Avatar
12 point
Old Apr 21, 2006 | 03:01 PM
Lan's Avatar
Lan
Default Re: special socket for flywheel bolts? (robTypeGs-R)
Elaborate then so I know
Old Apr 21, 2006 | 05:08 PM
IN VTEC's Avatar
Negatory on the lock-tite is what he means....I think. I never use lock-tite on any of that stuff. It just makes it harder to remove later on.
Juan_Mitosis
60
May 20, 2016 07:20 AM
Acidcrakker
Jul 3, 2012 05:35 AM
4d_ef_bucket
Jul 20, 2010 09:28 PM
dacrxguy
21
May 28, 2009 06:25 PM
Mr.Luder
Oct 17, 2006 01:51 PM
