Quick GSR Manifold wire question (which goes to IAB and IAC)
Old Apr 21, 2006 | 07:44 AM
Vintech's Avatar
Default Quick GSR Manifold wire question (which goes to IAB and IAC)
I got my head back on and everything, I always forget which one goes where. Which plug goes to the IAB
and Which plug goes to IAC and the third is one that I don't use.
I think the Pink/Blue & Black go to the IAB
and the Yellow/Black & red go to IAC
can some one help me out
Old Apr 21, 2006 | 09:09 AM
Muckman's Avatar
Moderator in Chief
Default Re: Quick GSR Manifold wire question (Vintech)
Looks like your need the longer wire to make it all the way over to the IAC. I think its the shorter grey one. The default off position is the high rpm mode. So if its hooked up correctly it should change positions when you turn the ignition on.
Old Apr 21, 2006 | 09:11 AM
Vintech's Avatar
Default Re: Quick GSR Manifold wire question (Muckman)
They are long enough to make it they both make it to the IAB, some one just told me that Pink/Blue goes to IAB's. That's what I thought also.
mjrino
Apr 17, 2008 12:07 PM
Vintech
Dec 19, 2006 09:49 PM
Mr. LS VTEC
Oct 25, 2006 01:36 AM
Vintech
Apr 21, 2006 09:09 AM
slotec
Sep 6, 2004 09:13 AM
