ls....type R
Old Apr 21, 2006 | 05:47 AM
EJ1_228's Avatar
Default LS/VTEC
ok I have and ls/vtec motor in my garage..... I want to get more power out of it and was wondering, could I put the type r pistons in without any boring or sleeving?? please let me know so I can go a head and order them..... thanks!!
Old Apr 21, 2006 | 08:51 AM
Padawan's Avatar
Darth ModerVader
Default Re: LS/VTEC (EJ1_228)
Assuming the cylinder walls are in good condition, simply honing them should be sufficient.
Old Apr 21, 2006 | 11:42 AM
Speed Infliction's Avatar
yes ITR pistons will fit your block. if you want more compression you can go with the CTR pistons.
Old Apr 21, 2006 | 05:42 PM
so lazy's Avatar
I would order CTR pistons due to the higher compressions thats what i had in my ls vtec set up. with ARP rod bolts. itr is ok but why not add acouple of more dollars and get higher compression ones... also dont forget the ITR or GSR or CTR OIL PUMP... : ) good luck.
Old Apr 21, 2006 | 11:48 PM
JDMtype Eg6's Avatar
if you're going to use pct pistons it would be a good idea to have a good tuner, also it would be prefered to use 93 octane if its available to you.
bOOsT-FeIn
Oct 30, 2006 07:55 PM
N20civicB18
Jul 27, 2004 08:15 AM
JDMBB2
Feb 26, 2004 07:09 AM
unsurpassedLS
May 7, 2002 07:34 PM
MXPX
Jun 20, 2001 06:33 PM
