ugly headlights
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doodooheadfart »</TD></TR><TR><TD CLASS="quote">awesome
where i can i get this?
Bump, I wanna know this too, because i always trashed my old headlights, after waxing and getting nowhere, when thinking it was the solution
damn
im gunna go get some tomorrow
and here i was thinking it was on the inside and started saving up for new headlights
then while i was working on my car i looked at it closer
oh well, more money to invest in my engine i guess...
Youre gonna need more than just plastic polish for those lights dude! Id go out and get some 1000, 1500, and 2000 grit sandpaper and start wetsanding. Then get some 3M rubbing compound from wal mart and get the sand marks out. Then get the plastic polish, and polish the hell outta them!!!
My lights werent half that bad, and I had to sand them. Good luck bro
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doodooheadfart »</TD></TR><TR><TD CLASS="quote">your pics are down bro</TD></TR></TABLE>
Bandwidth exceeded.
Bandwidth exceeded.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crono139 »</TD></TR><TR><TD CLASS="quote">Bandwidth exceeded.
are you guuna fix them?
</TD></TR></TABLE>are you guuna fix them?
Sanding with water... basically. If you dont know how to wetsand I would suggest practicing on a scrap piece of plastic or something. Basically when you wet sand you want to keep your piece of sand paper wet at all times, as well as the area that you are sanding. When doing your headlights, make sure that you only go in a back and forth motion across the lens, otherwise you will have tons of swirl marks and it will be a huge pain in the *** to get them out..... Searh in the FAQ's section to find out how to do this.....there have been sooo many write ups done!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TRE_ »</TD></TR><TR><TD CLASS="quote">they make a plastic cleaner too... I usually use that first, then hit it with the polish.
i usually wetsand with 1000, plastic cleaner, then plastic polish, then wax the headlights
</TD></TR></TABLE>i usually wetsand with 1000, plastic cleaner, then plastic polish, then wax the headlights
