check engine light
ok im trying to run my turbocharge accord with the stock ECU, and i got a FMU 12:1(vortech), an external MSD pump, and an inside the tank walhbro pump. i got a missing link for the MAP sensor, and still the check engine light still on. WHY???. it was on before i installed the missing link, and i changed the oxygen sensor also. so i disconnected the battery cable and turn it off. However, when i turn the car on the check engine light comes back. WHY???
what year is your car ?
get a code reader or do the jumper trick and pull the code out, that will tell you whats wrong
check engine means = something not working or missing (so check engine)
palmtree
Jan 28, 2013 12:06 PM
oilspot
Feb 24, 2009 10:16 AM
