jdm spark plug VS usdm spark plugs. difference?
Old Apr 20, 2006 | 04:41 PM
lv6l's Avatar
Default jdm spark plug VS usdm spark plugs. difference?
running jdm d16a. my plugs that came with the car is ZFR6J-11 NGK. i recently bought ZFR5J-11 NGK. which are usdm d16z6 replacement. i look in my manual and it said the jdm plugs are design to run in hot weather or continous high speed.
question is what are the difference? which one do you guys recommend?
Old Apr 20, 2006 | 05:15 PM
. a d a m's Avatar
Default Re: jdm spark plug VS usdm spark plugs. difference? (lv6l)
You will be fine with the usdm plugs.
Old Apr 20, 2006 | 05:21 PM
Syndacate's Avatar
JDM SPARK PLUGS HAVE 40 EXTRA HP (10 IN EACH CYLINDER!!!) G2 GET THE JDM, HAVE TO
No, seriously they are the same...hte USDM will be fine, any dynoed difference would be machine error..
Old Apr 20, 2006 | 05:39 PM
-Gambit-'s Avatar
Default Re: (Syndacate)
same stuff, but now if your talking about jdm interior clips vs usdm ones thats a whole other story there buddy
Old Apr 20, 2006 | 06:28 PM
lv6l's Avatar
haha.
thanks guys.
Old Apr 20, 2006 | 08:38 PM
verycleanhatch's Avatar
I am not sure about the engine you got but some jdm engines are higher compression and need a colder plug.
Old Apr 20, 2006 | 10:20 PM
lv6l's Avatar
well its pretty much the same as the usdm d16z6. but on my timing belt cover it recommended the jdm plugs. thats why i'm here asking this question. so what do you think?
Old Apr 20, 2006 | 10:28 PM
SHG_Beans's Avatar
Yeah only difference i think is the heat range on those plugs but youll be fine
Old Apr 20, 2006 | 10:29 PM
lv6l's Avatar
Default Re: (ek gripper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek gripper &raquo;</TD></TR><TR><TD CLASS="quote">Yeah only difference i think is the heat range on those plugs but youll be fine</TD></TR></TABLE>
so the jdm would run better in hot weather or when hot than the usdm? cuz i live in california and it gets pretty hot. summer is almost here.
Old Apr 21, 2006 | 04:10 AM
Sleepy_Red_hatch's Avatar
Default Re: (lv6l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lv6l &raquo;</TD></TR><TR><TD CLASS="quote">
so the jdm would run better in hot weather or when hot than the usdm? cuz i live in california and it gets pretty hot. summer is almost here.</TD></TR></TABLE>
the ambient temperature doesn't matter as much as the cylinder temps, you should be alright, such a small difference is negligible.
Old Apr 21, 2006 | 04:53 AM
T-RO's Avatar
If the motor says run a specific plug then use that one.
Old Apr 21, 2006 | 11:42 AM
. a d a m's Avatar
Default Re: (lv6l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lv6l &raquo;</TD></TR><TR><TD CLASS="quote">well its pretty much the same as the usdm d16z6. but on my timing belt cover it recommended the jdm plugs. thats why i'm here asking this question. so what do you think?</TD></TR></TABLE>
It recommends the jdm plugs because it is a JDM engine, why would a JDM engine recommend USDM plugs?
NinjaJDMB18c
Oct 21, 2013 08:18 AM
NXSpoon
Oct 7, 2004 12:22 AM
Mr_CRX
Jul 19, 2004 06:49 AM
turkdog
Jul 7, 2003 08:08 PM
