Suspension & Brakes Theory, alignment, spring rates....
What are the signs/symtoms of a bad axle?
Old Apr 20, 2006 | 01:55 PM
lalaine17's Avatar
Default What are the signs/symtoms of a bad axle?
I'm not sure if its a bad axle or something.. I drive around sometimes and i hear a squeak. Its not on going though. Just once in a while.
What you guys think?
Old Apr 20, 2006 | 05:56 PM
PIC Performance's Avatar
Default Re: What are the signs/symtoms of a bad axle? (lalaine17)
Other than snapping, an axle can go bad if one (or both) of the cv boots rip and the grease leaks out. Thats pretty easy to spot, and you will have great all over the area. Thats your first visual clue.
When an axle starts going bad, you will also hear click-click-click-click when turning, and eventually even when going straight. You don't to get to the point where you hear the clicking when going straight.
Old Apr 21, 2006 | 12:25 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: What are the signs/symtoms of a bad axle? (PIC Performance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PIC Performance &raquo;</TD></TR><TR><TD CLASS="quote">Other than snapping, an axle can go bad if one (or both) of the cv boots rip and the grease leaks out. Thats pretty easy to spot, and you will have great all over the area. Thats your first visual clue.
When an axle starts going bad, you will also hear click-click-click-click when turning, and eventually even when going straight. You don't to get to the point where you hear the clicking when going straight.</TD></TR></TABLE>
Well said. Bad inner joints can also cause vibration on accelleration.
Old Apr 21, 2006 | 09:28 AM
lalaine17's Avatar
Default Re: What are the signs/symtoms of a bad axle? (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">
Well said. Bad inner joints can also cause vibration on accelleration.</TD></TR></TABLE>
My car vibrates while under load and upon acceleration. So I'm guess its a bad inner joint.
What do I look for around the inner joint. Grease? a rip on the boot?
Let me know so I can tell my big bro what to look for.
Old Apr 21, 2006 | 11:12 AM
94eg!'s Avatar
#1 Super Guy
Loved
Look for a rip in the boot, and grease flug straight out in a radial pattern on everything around it...
ahloung
15
Mar 14, 2006 11:52 AM
b20integrapower
Feb 15, 2006 07:57 PM
LudeJdm
Jun 2, 2005 05:43 PM
.M.
Sep 14, 2004 10:06 PM
Black_Accord
Jul 14, 2003 08:08 AM
