Calling all JRSC Water/Methanol injection user.....need advice on setting pressure switch
What psi are you guys set up for the pressure switch to activate the water injection? Im boosting 12 psi and my pressure switch is set at 10psi. I hit 10 psi at around 3500 rpm and max boost of 12 psi at around 5500 rpm.
HOw do you determine what psi to set the pressure switch?
