Removable rollbar for ITR?
Old Apr 7, 2002 | 06:53 PM
rltrock's Avatar
New User
Default Removable rollbar for ITR?
OK, I know someone posted on this last year, but can't find it under search:
Is there a rollbar out there for the ITR that is (partially) removable, so that the back seat is still usable and safe?
R.
Old Apr 7, 2002 | 06:56 PM
Reid's Avatar
Global Moderator
Default Re: Removable rollbar for ITR? (rltrock)
Autopower makes a rollbar with an optional removable center section so access to the rear seats is easier.
Old Apr 7, 2002 | 07:17 PM
Floyd's Avatar
Default Re: Removable rollbar for ITR? (George Knighton)
And I'm not sure how "safe" it is either. Lots of metal back there close to your passengers' heads.
Old Apr 7, 2002 | 07:23 PM
davidnyc's Avatar
Default Re: Removable rollbar for ITR? (Floyd)
I think the pic was of a PY ITR with a Autopower Cage fully padded with Yellow Pads.
Here is the tutorial from http://www.itrca.com
http://www.itrca.com/faq/mod_autopower_rollbar.asp
Old Apr 7, 2002 | 08:04 PM
RacingE_Teg's Avatar
Default Re: Removable rollbar for ITR? (Reid)
Actually...they used to offer the removable center section, but not anymore. At least that's what they told me when I placed my order a few weeks ago.
Old Apr 7, 2002 | 08:07 PM
travis's Avatar
Default Re: Removable rollbar for ITR? (davidnyc)
I'm glad to see that tutorial is still getting around
To answer the question, there is NO ROLLBAR that I know of that would be safe with people in the back seat. I don't care how much you pad it...roll bar padding is there to keep your helmet from splitting open, and MAYBE keep your bones from snaping around the bar. Pading does not make the metal bars safe. Look at how little room there is for people in the back, even with the cross braces removed (you'll have to picture them removed, I don't have a pic):
Old Apr 7, 2002 | 09:53 PM
comptechgsr2000
Guest
Posts: n/a
Default Re: Removable rollbar for ITR? (ITR#231)
Try this!
Old Apr 7, 2002 | 09:56 PM
R you serious's Avatar
Default Re: Removable rollbar for ITR? (comptechgsr2000)
that looks like the j's racign bar. ive got it and must say it is quite nice.
Old Apr 7, 2002 | 09:59 PM
Warren's Avatar
Wrong-Way Wang
Sadly no. There isn't a way to get a rollbar in there and remove enough to be safe for passengers. You can get the removable cross section to use the back seat for storage, but that's about it.
Don't get a harness bar. They might as well be called poseur bars, or decrapitation bars.
Warren
Old Apr 7, 2002 | 10:15 PM
1033's Avatar
Default Re: Removable rollbar for ITR? (Warren)
i heard that harness bar is dangerous
but i dont know how it looks like
and why it is dangerous
Old Apr 7, 2002 | 10:20 PM
Reid's Avatar
Global Moderator
Default Re: Removable rollbar for ITR? (1033)
Harness bars, when used with harnesses on the track, can lead to severe injury in the event of a rollover.
If you want to use harnesses on the track, get a rollbar or a rollcage. We don't ever need to see a thread where someone was killed as a result of using harnesses without proper rollover protection.
Old Apr 7, 2002 | 11:02 PM
GokuSSJ4's Avatar
just don carry any people in the back seat , if you want a rool bar that bad!!!
[Modified by Spoon1, 8:02 AM 4/8/2002]
Old Apr 8, 2002 | 08:48 AM
norice's Avatar
If the search function worked I could probably find the answer to this, but ... how much does the Autopower setup weigh?
Old Apr 8, 2002 | 08:50 AM
Warren's Avatar
Wrong-Way Wang
Default Re: Removable rollbar for ITR? (norice)
I think I heard the mild steel version is about 60 lbs all said and done.
Easily worth the weight.
Warren
allmotaR
Aug 29, 2013 01:02 PM
BenB
Jul 4, 2007 06:22 PM
Ross
Jun 1, 2004 10:12 AM
ITRFetish2000
Apr 22, 2004 04:02 PM
Lip
Jul 29, 2002 09:54 AM
