96 civic y8 manifold swap on a y7 idle problem...HELP
Old Apr 19, 2006 | 11:06 PM
LiL JoN's Avatar
Default 96 civic y8 manifold swap on a y7 idle problem...HELP
i have a 96 civic with a y7 motor and did a y8 manifold swap manifold is on had 3 wire iacv and did 2 wire not using orange on the 3 wire and put yellow/black to green and black/blue to black but idles funny and check engine light code 4 running stock ecu..... dont know if i have to do more..... HELP
Thanks Jon
Old Apr 19, 2006 | 11:40 PM
LiL JoN's Avatar
Default Re: 96 civic y8 manifold swap on a y7 idle problem...HELP (LiL JoN)
HELP
Old Apr 19, 2006 | 11:59 PM
LiL JoN's Avatar
LATE HELP BUMP
Old Apr 20, 2006 | 07:48 AM
LiL JoN's Avatar
Old Apr 20, 2006 | 07:52 AM
suprmods's Avatar
you bolted the manifold down correctly, and it fits fine? new gasket? no vacuum leaks anywhere?
Old Apr 20, 2006 | 07:57 AM
LiL JoN's Avatar
Default Re: (suprmods)
yes just the idle code 4 light
Old Apr 20, 2006 | 08:12 AM
LiL JoN's Avatar
Default Re: (LiL JoN)
do i have to use the y7 iacv and block the manifold ?? using stock ecu
triple5soul4165
Feb 20, 2009 03:20 PM
ATL-EF squad
Nov 30, 2008 10:23 AM
awdriscol4
10
Aug 5, 2005 05:03 PM
WangChung
16
Jan 26, 2005 07:43 PM
phasewest
Dec 12, 2004 08:57 PM
