JG Throttlebody D series
Old Apr 7, 2002 | 06:45 PM
ion_four's Avatar
Default JG Throttlebody D series
Check out the link, it was on a 93 Civic EX for about 2000 miles and is in perfect shape. should work on 92-95 Civics and all SOHC Del Sols. Also should work on 88-91 Civics and CRXs with a bit of a mod because of the MAP sensor mounting(I think). http://cgi.ebay.com/ebaymotors/ws/eB...tem=1819606110
I also have a testpipe for sale on ebaymotors for same cars. http://cgi.ebay.com/ebaymotors/ws/eB...tem=1819612199
I'd also take trades(with cash going either way)...looking for missing link (model 002), Blow Off Valve, intercooler(small to medium in size), FMU, turbo manifold for T-25 (including HF, STD civic, crx with adaptor), rear sway bar...yeah, so if you have something cool, lemme know
[Modified by ion_four, 3:53 AM 4/8/2002]
Old Apr 7, 2002 | 07:05 PM
Inigo Montoya's Avatar
Default Re: JG Throttlebody D series (ion_four)
I am interested, do you happen to know if this will work on a d16y8 engine? I have not looked closely at the two designs to see the differences. Thanks for your help.
Old Apr 8, 2002 | 01:02 AM
ion_four's Avatar
Default Re: JG Throttlebody D series (inigo9910)
What car is that model in? I'm almost certain that the bolt pattern and everything is the same on all the D series manifolds, it's just that some have the MAP sensor on the firewall and some have it on the TB. This is the kind where the MAP sensor is right on the TB, but you can hook up the other kind with a vaccuum hose. So, it should work. You can check out the pics on the auction if they aren't working I can send them. just message me your email or whatever.
Old Apr 8, 2002 | 07:34 AM
Ah, the D16Y8 is from a 1998 ex coupe, well at least in my case. SOHC Vtec, i might post this over in the tech forum and seeif they have any answers.
surfingsk8r
Mar 3, 2005 08:28 PM
gaydm.accord
Dec 14, 2004 09:22 PM
Boofster
Feb 5, 2004 07:55 AM
