goddamnit!! my integra is starting to piss me off.. power window related.. plz help!
ok, so i've been doing some maintenance on my car that i've been neglecting to do when i had a gf, now that i kicked that bitch to the curb, i can start fixing my true love..
ANYWAYS!!
i just did the cv axle (passanger side, driver side was done a few months ago), picked up some drilled rotors to replace the warped ones.. and was going to buy the front left and front (radiator side) motor mounts, but now i cant, why? well i go to walmart to pick up some house paint plastic inserts for tomorrow when i paint the house, when i go to roll up my windows.. and they dont go.
so i kept messin around with it, and the passanger side went up a bit, then stopped. then i waited a few, and tried to put it down, and it went down a bit, then stopped again, then i waited some more, tried to put it up, and it went up all the way and stopped working. passanger switch worked, but not better than the driver side.
the driver window wont even go up now at all, its stuck down. checked the fuses under the hood, all good, checked them under the dash, all good. so idk what it could be, either both motors went out at the same time
OR its the relay..
so my question is, where the hell is the relay located and how do i check to see if its working or not, and how do i check to see if the motors are still good?
Car: 1991 LS 3-door
ANYWAYS!!
OR its the relay.. so my question is, where the hell is the relay located and how do i check to see if its working or not, and how do i check to see if the motors are still good?
Car: 1991 LS 3-door
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rgaray »</TD></TR><TR><TD CLASS="quote">Not sure on a DA, but on DC it's next to the hood release.
Maybe it's just the switch?</TD></TR></TABLE>
well are you ready for some great Gen2 integra humor??
took the door pannel off, and what do i find? low and behold, the motherfuck harness plug came off! guess i got owned from 15 years of closing the door..
*cliff's - it works now! haha*
thanx guys, or guy
thanx guys, or guy
Harrypd
Jul 11, 2009 04:19 PM
mugenpower92ls
Mar 23, 2007 05:50 PM
OdysseyHF
Aug 25, 2005 12:31 PM
