missing resistor box = no spark??
Old Apr 19, 2006 | 09:39 PM
go2sleep's Avatar
Default missing resistor box = no spark??
i bought a ls motor and it seemed to have had a resistor box spliced in.
i had the wires soldered. now, would missing the resistor box keep my engine from starting?? there's no spark either.
Old Apr 20, 2006 | 07:36 AM
go2sleep's Avatar
up. need to get this thing started.
Old Apr 20, 2006 | 11:58 AM
JimBlake's Avatar
Default Re: (go2sleep)
Are you sure there's no spark? Fix that first. Depending on what's wrong with spark, that might fix the fuel problem.
Old Apr 20, 2006 | 07:28 PM
go2sleep's Avatar
installed a new cap and rotor. still nothing. all it does it just crank. i dont smell any fuel on the tips of the spark plug either
Old Apr 21, 2006 | 04:30 AM
JimBlake's Avatar
Check for actual spark by pulling a plug & watching it?
Then troubleshoot the triggering system.
Sensors in the distributor (CYP, CKP, & TDC) tell the ECU when to fire the spark & injectors. If those are bad (or bad wiring) then the ECU won't know the engine's turning.
Then the ECU sends a signal to the ICM (ignitor). The ECU can tell if that circuit isn't properly connected, then it won't run the fuel pump. But in that case you'd get a CEL for 'ignition trigger signal'.
BTW, what year? Some of this stuff is a little different for some years.
Old Apr 23, 2006 | 06:59 PM
go2sleep's Avatar
it's a 97/98 LS block and head with a obd1 intake manifold, injectors, distributor (i believe), and wiring.
i'm thinking there's something wrong with the coil or the ignition module.
Old Apr 24, 2006 | 02:57 AM
ccivic's Avatar
You should get spark, but not fuel. The resistor box goes in between power and injectors. Therefore, your injectors aren't getting any power without it.
Old Apr 24, 2006 | 05:50 AM
Jmunk's Avatar
Check your ground wires. I've been owned by them before.
Old Apr 24, 2006 | 08:27 AM
FalkenSiR's Avatar
Default Re: (ccivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccivic &raquo;</TD></TR><TR><TD CLASS="quote">You should get spark, but not fuel. The resistor box goes in between power and injectors. Therefore, your injectors aren't getting any power without it. </TD></TR></TABLE>
Or you could have burned them by overpowering them. The resistor box is to lower voltage, I believe.
Old Apr 26, 2006 | 07:40 PM
go2sleep's Avatar
i swapped in a new distributor and put in a resistor box. all it does is still crank and not turn over. i think im just going to put in a new engine harness.
just want to clarify if a 92-95 civic dx enigine harness would work. (i have a 94 auto and a 92 manual harness laying around somewhere)
Old Apr 27, 2006 | 07:38 PM
go2sleep's Avatar
up for an answer on the engine harness
Old Apr 29, 2006 | 04:29 PM
User 5426's Avatar
Hmmm, maybe a bad ecu.
Old May 19, 2006 | 02:49 AM
driftboy's Avatar
do you have fuel press but the injectors wont open ? i had the same problem and i checked all the grounds and one was takin off from one of my friends after i repined everything i found it i was so pissed
Old May 19, 2006 | 07:30 AM
trickeng's Avatar
Default Re: (driftboy)
if you are running low impedience injector without a resistor box it will not keep the car from starting but with burn out your ecu's injector driver.
could be an ignitor failure. this would cause no spark or fuel.
Old May 19, 2006 | 10:13 AM
luis666's Avatar
Default Re: (trickeng)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trickeng &raquo;</TD></TR><TR><TD CLASS="quote">if you are running low impedience injector without a resistor box it will not keep the car from starting but with burn out your ecu's injector driver.
right on
car should start even w/o the resistor box but will fry ECU in the long run, get one ASAP
Old Jun 8, 2006 | 02:18 AM
go2sleep's Avatar
Default Re: (luis666)
i changed the wiring harness and the car started right up. i also had a CEL 16 [fuel injectors], but they all read 11.9 to 12.0 ohms.
i believe the absence of the resistor box is what kept my car from starting.
thanks for all the input
97ek-t
May 1, 2010 10:08 AM
turbojdmhatch
Jun 9, 2009 09:36 PM
mynameisrand
Jun 2, 2009 08:31 AM
burnh22
Sep 27, 2008 11:08 AM
b16hatch66
Apr 13, 2005 11:26 AM
