F20C broken roller-any thoughts (pics)
Old Apr 19, 2006 | 08:38 PM
blues2k3's Avatar
Default F20C broken roller-any thoughts (pics)
any thought on this...thanks
Old Apr 19, 2006 | 09:03 PM
S2KP's Avatar
overrev?
Old Apr 19, 2006 | 09:06 PM
miller's Avatar
Default Re: F20C broken roller-any thoughts (blues2k3)
it could have been caused by a number of things. can you give us some info about the parts in the head?.... ie springs and seat pressure's at various heights and also how big of a cam. what was the valve lash set at? does the cam have any type of markings on it?
Old Apr 19, 2006 | 09:34 PM
cruizinmax's Avatar
I've seen something like that on a dsm that broke the timing belt. When the pistons came up into the valve it broke the rollers on the cam followers.
Old Apr 19, 2006 | 10:49 PM
fknfast's Avatar
call hardtopguy hell know in a sec.
we get s2k heads in left and right with crap like that
Old Apr 20, 2006 | 02:51 AM
blues2k3's Avatar
Default Re: F20C broken roller-any thoughts (miller)
the head was built by Earl so hopefully he will chime in with some of the details...the cams are stock and had some slight markings on the lobe where the roller was split in half. Technically the head was not over-revved (taken to 9k) since it could rev up to 10k. From what I recollect it was rev tech parts used. Thanks for the feedback.
Old Apr 20, 2006 | 05:00 AM
miller's Avatar
i would take the rest of the rockers out and have them all fluxed/rayed to see if hair line cracks are forming within the other rollers. the other info i was aking for might hold the key to your answer.
Old Apr 20, 2006 | 07:44 AM
earl's Avatar
ouch, never saw that happen before. Be sure to check the cam lobe closely for a flat spot on it. No idea why that should have happened.
Old Apr 20, 2006 | 07:48 AM
MidShipCivic's Avatar
Holy crap a roller broke? IT broke clean off too.
I'm gonna blame it on the material.
Old Apr 20, 2006 | 07:52 AM
blues2k3's Avatar
Default Re: (MidShipCivic)
thanks, yep no flat spots on the cam...I hope it was material based but will check everything as Miller stated.
Old Apr 20, 2006 | 10:26 AM
*Boostwerks*'s Avatar
wow that is one clean break. Looks like it was cut with a laser.
Old Apr 20, 2006 | 06:46 PM
blues2k3's Avatar
Default Re: (Bryson)
well the team and I had an opportunity to change out the broken roller tonight, however, it gets even worse. Once we got it back together we noticed a slight noise which caused the initial inspection. So we checked again and found a similar crack on the intake side on a different lobe (non-vtec) roller. This was a single crack which was even more percise and straight. This is very puzzling since everything else checks out fine...
Old Apr 20, 2006 | 07:38 PM
JDMCRX's Avatar
Default Re: (blues2k3)
Flaw in the casting and it just cracked :
Old Apr 20, 2006 | 08:40 PM
Hondatec38's Avatar
Default Re: (JDMCRX)
Valves adjusted to tight or loose maybe? I dunno.
Old Apr 20, 2006 | 09:46 PM
mrbsponge's Avatar
doesnt seem to be naything like lack of oil or anything, doesnt look like anything is burnt up
you could send it to a couple of places and have them X-ray it and check the structure of it, but i really just think it was a flawed piece
Old Apr 21, 2006 | 03:57 AM
blues2k3's Avatar
Default Re: (mrbsponge)
thanks everyone, valve adjustment seemed fine, all within spec. Oiling was okay too as seen. Just unusual that two pieces were possibly flawed. One on the intake side and the other exhaust side. Both the non-vtec rollers. I visually inspected the others and they seem fine but will have to send them out to be xrayed..
Vagitarian
Sep 14, 2012 09:22 PM
HOM DON
Apr 10, 2011 10:27 PM
skaterp14
Jun 8, 2010 07:03 PM
skaterp14
Mid-Atlantic (Sales)
22
Aug 23, 2009 06:42 PM
97twodoor
11
Jun 5, 2009 03:40 PM
