5th Gear Grinding
Old Apr 19, 2006 | 04:23 PM
gsrrican84's Avatar
Default 5th Gear Grinding
I had a new stage 2 clutch put in and after i broke in the clutch for the first 500 miles I noticed 5th gear grinds. But if I were to step on the clutch pedal two times it won't grind at all. Another thing is when under 50 mph it wont grind as well. Any suggestions or mechanical problems that need to be fixed please let me know i would appreciate it
Old Apr 19, 2006 | 08:14 PM
DA is best's Avatar
did you have your clutch line disconnected because you might need to bleed or rebleed it, so there is no air trapped in the lines
Old Apr 20, 2006 | 12:53 PM
gsrrican84's Avatar
Default 5th gear grinding
Now when i bleed it i should waste 2 bottles of brake fluid or more? even though it sounds silly but i know when you bleed an item you have to have sufficient products to do so.
Old Apr 20, 2006 | 12:58 PM
Regular Series's Avatar
Default Re: 5th gear grinding (gsrrican84)
You shouldn't even need a single bottle. Just keep bleeding until the fluid is clear and bubble free. That shouldn't take long since the clutch system needs very little fluid.
My guess is that your fifth gear syncro is worn. When you double-clutch it you match the speed of the engine and layshaft so the syncro doesn't have to. I would get some new MTF in your tranny if you haven't done that in a while. Otherwise, you may need to keep double clutching fifth to prevent destroying the gear entirely. Metal shards are not good for your transmission.
Old Apr 20, 2006 | 09:04 PM
DA is best's Avatar
you no it's funny because i just got done putting a stage 2 clutch in my car and before i put the new clutch in my 3rd gear grinded when i shifted now it's doe'st because i didn't check my fluid level..now it shifts fine
Old Apr 21, 2006 | 05:46 PM
gsrrican84's Avatar
Default Re: 5th Gear Grinding (gsrrican84)
i forgot to mention to i got a lightened flywheel as well if that makes a difference it was a whole package
blasterman87
Feb 21, 2010 03:38 PM
niceprelude
Nov 7, 2008 10:22 AM
civicgsr116
Oct 2, 2007 11:09 PM
sireg6
Dec 11, 2006 12:31 AM
Rod.
Nov 11, 2004 09:25 AM
