gsr block ls crank?
oil squaters are removed...but im told the gsr rods wont work on it...i dont need custom pistons its a normal bore.... it suppolsy will bump compression a lil
gotta use different rods, unsure about oil squirters, knew you had to with a GSR crank in an LS, so prolly have to the other way around... and im not sure, but i believe you might have a problem with the depth of the oil pan or something, possible contact between crank counter weights and oil pan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmzintegra »</TD></TR><TR><TD CLASS="quote">you will have to plug up the oil squirters, and use ls rods. </TD></TR></TABLE>
you have to just bend them up a bit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowassciv33 »</TD></TR><TR><TD CLASS="quote">but im told the gsr rods wont work on it...</TD></TR></TABLE>Yeah they will. With custom pistons.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowassciv33 »</TD></TR><TR><TD CLASS="quote">i dont need custom pistons its a normal bore.... </TD></TR></TABLE>There is alot more to a piston than bore size.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowassciv33 »</TD></TR><TR><TD CLASS="quote">it suppolsy will bump compression a lil </TD></TR></TABLE>All other things being the same this is correct. However it won't be as rev friendly as the gsr was.
blu3g
26
Aug 2, 2005 09:22 PM
1heavy4dr
Jul 26, 2005 05:26 PM
vteczone
Nov 24, 2004 12:22 AM
