Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Custom coilover Question, Suspension travel/droop questions...Guru's report in! ;)
Old Apr 19, 2006 | 02:54 PM
sleepingEg8's Avatar
Default Custom coilover Question, Suspension travel/droop questions...Guru's report in! ;)
Ok heres the deal. got a set of bilstein full coilovers recently and found that the spring rates are much too soft(250f/200r, BLAH!!!!). Custom rates are in order as are revalves for my spring rates...
so.. the only thing I have a problem with is how you proportion wheel/shock travel... meaning if you have 5 inches of total shock travel, where do you want the car to sit at ride height in the stroke. How much up and down travel do you want/need.
The spring rates I have worked out are 450f/600r with a 320/120 front valving, and a 300/100 rear valving. This is on a stripped 91 integra chassis. stock front bar, itr rear bar.
I am using custom top mounts to get the right ride height without sacrificing shock travel, but the front is hard to get right with the reduced body height.
What do you guys think!
Old Apr 19, 2006 | 03:17 PM
Lo-Buck EF's Avatar
if you have 5 inches of travel from full droop to full bottom out/tire hitting something, your gonna want the shock to rest with ~1-1.25 before full droop. that should give you plenty of compression travel and enoung droop to keep the wheel on the ground.
what car is this for? the DA?
Old Apr 19, 2006 | 04:32 PM
rallybird's Avatar
Default Re: Custom coilover Question, Suspension travel/droop questions...Guru's report in! ;) (sleepingEg8)
Post pics. of your setup.
Old Apr 19, 2006 | 10:11 PM
Default Re: Custom coilover Question, Suspension travel/droop questions...Guru's report in! ;) (rallybird)
of what specifically... the coilovers are from an EG they are on a da.. I am modifying front forks to position the strut closer to the axle and extending the top hats to gain the front travel I want. Right now I have the stock springs...
Old Apr 20, 2006 | 05:51 AM
rallybird's Avatar
Of your modified parts.
Old Apr 20, 2006 | 10:26 AM
slammed_93_hatch's Avatar
FYI the EG/dc shocks are longer to begin with then the DA/ef ones.
there is a thread around here with pictures
Old Apr 21, 2006 | 08:22 AM
Default Re: Custom coilover Question, Suspension travel/droop questions...Guru's report in! ;) (slammed_93_h
these arent stock dc/eg stuff.. they are shortened body bilstein coilovers..i will take some measurements to compare
Old Apr 21, 2006 | 07:48 PM
stupid double posts...
Modified by sleepingEg8 at 1:24 AM 4/22/2006
Old Nov 4, 2006 | 09:07 PM
Bringing this back from the dead... I ended up not being able to use the shortened forks on the front because of upper arm clearance... I ran out of fender clearance before shaft travel. There is a reason why short forks weren't super popular for racy guys!
98 ITR
Feb 1, 2008 06:16 PM
vincent001
Suspension & Brakes
Mar 5, 2007 06:42 PM
JDM PRO
Apr 2, 2004 12:06 PM
teg92
Apr 25, 2002 02:04 AM
