Current engine turbo'd or??
Old Apr 19, 2006 | 01:26 PM
Sick_TR_TEG's Avatar
Default Current engine turbo'd or??
Ok, here are my thoughts....
Should i take the 5k and put it into a Sick turbo kit, or should i swap out my LS engine for a JDM ITR engine? or, should i get the turbo kit run it with my LS then could i eventually run my turbo setup with the JDM ITR motor? is this possible or just a pipe dream?
Old Apr 19, 2006 | 01:35 PM
BlackDAy's Avatar
Default Re: Current engine turbo'd or?? (Sick_TR_TEG)
it all depends on u. u could slap a turbo on an ls and rock ****, or an itr...but the comp isnt exactly as low as an ls motor. i would just build ur ls and put the turboz on it.
Old Apr 19, 2006 | 01:43 PM
DirtyBirdJR's Avatar
congrats on the 20millionth repost
Old Apr 19, 2006 | 03:17 PM
Fida's Avatar
just get a b16 head and get all your turbo **** go ls-vtec turbo
Old Apr 19, 2006 | 03:40 PM
yee SERIOUS's Avatar
Default Re: Current engine turbo'd or?? (Fida)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fida &raquo;</TD></TR><TR><TD CLASS="quote">just get a b16 head and get all your turbo **** go ls-vtec turbo</TD></TR></TABLE>
there go. or just go ls turbo. you don't need to spend 5k on a sick turbo setup. lol 3k will be more than enough for a custom kit put together by yourself. you can budget 1k for tuning and have another 1k for extra stuff for you motor. you'll see that when you go boost, you'll need a catch can setup, better tires, etc etc. how many miles on your integra?
Old Apr 19, 2006 | 03:58 PM
InfamousDC2FI's Avatar
I would turbo the ls.....lots more power for your money.....it would kind of be unreasonable to turbo a b18c5 or jdm ITR motor since the compression ratio is higher on it then the ls motor....
**** for $5000 you could almost build a ls block and have a decent turbo kit and make 300 ponies to the wheels easy on a daily driver....
Old Apr 19, 2006 | 05:32 PM
Micha's Avatar
FAILWGN
Default Re: Current engine turbo'd or?? (InfamousDC2FI)
get an SC61 turbo, and get new rods and pistons, and put them on your ls motor. You can have 300 horses pretty easy. Just make sure you get the best tune out there.
Murk 'EM
Mar 10, 2011 03:03 PM
JDMJunior
Jul 24, 2006 06:53 AM
blueturboteg
Nov 14, 2003 02:29 PM
JDMVTEC
Oct 13, 2003 08:47 AM
Integra717
May 19, 2002 11:22 AM
