new vtec solenoid and BAM! no more engine...
Old Apr 19, 2006 | 01:11 PM
Gods own's Avatar
Default new vtec solenoid and BAM! no more engine...
Hey fellas,
Dont know if this is a stupid question, but my friend is swapping his motor to a SOHC d16 (he had same engine before just blew it, cant afford to upgrade) Anyways I've never installed an engine, but he said that the new engine was running but the vtec wasnt popping so he replaced the vtec solenoid. Now the engine wont even crank over! any ideas whats going on. again i've never installed an engine so this may be a stupid tread, but any suggestions or other treads would help. Did a search and didnt find anything. Thanks
Old Apr 19, 2006 | 01:22 PM
Schrader's Avatar
Make sure everything is connected, just replacing the VTEC solenoid won't make the car not start. Check all the easy stuff first batter, fuses, relay etc...
Old Apr 19, 2006 | 02:16 PM
hatchi's Avatar
Default Re: (Schrader)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schrader &raquo;</TD></TR><TR><TD CLASS="quote">Make sure everything is connected, just replacing the VTEC solenoid won't make the car not start. Check all the easy stuff first batter, fuses, relay etc...</TD></TR></TABLE>
ill second this idea
Old Apr 19, 2006 | 03:38 PM
Gods own's Avatar
Default Re: (hatchi)
BUMP
Old Apr 19, 2006 | 03:44 PM
schardbody's Avatar
theres no were near enough info in your post to even try to help. check fuel, spark, etc....
Old Apr 19, 2006 | 04:11 PM
Gods own's Avatar
Default Re: (schardbody)
alright, I'll talk with my friend tonight and get more info about the problem and hit you guys up later. Thanks
Black_horse
K Series
15
Apr 27, 2013 06:37 PM
F20Cdriver
Honda S2000
Feb 1, 2008 09:28 PM
IE_EG8
40
Jul 26, 2006 09:34 AM
Drum_Guru
May 17, 2003 07:19 AM
