Need a sub fram fixed... and tie bar issues
OK first off.. I need some one close to Everett wa that can straiten out a sub frame and reinforce it … it is bent like 1 inch on the driver side…
Next I am having clearance issues with a front tie bar for a (94 hb with b18b1) I bought a set of for A EG HB but with this engine it looks like the trans.. is to close to the bar…
It is about the with of the lines above… is the a tie bar set up for a eg with swap… or will I have to custom make one or something…
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tial-eg »</TD></TR><TR><TD CLASS="quote">OK first off.. I need some one close to Everett wa that can straiten out a sub frame and reinforce it … it is bent like 1 inch on the driver side…
i'd replaced the subframe otherthan try to repair it.
can you replace the sub fram where the rear lower controle armes go in to... is it not a unnabody subframe...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tial-eg »</TD></TR><TR><TD CLASS="quote">can you replace the sub fram where the rear lower controle armes go in to... is it not a unnabody subframe... </TD></TR></TABLE>
The rear subframe is a separate piece that is spot-welded onto the unibody. Honda sells it separately. It can be removed and replaced.
Super Trooper
12
Mar 10, 2007 03:56 PM
RzHybrid510
Nov 10, 2004 11:10 AM
