Need a sub fram fixed... and tie bar issues
OK first off.. I need some one close to Everett wa that can straiten out a sub frame and reinforce it … it is bent like 1 inch on the driver side…
Next I am having clearance issues with a front tie bar for a (94 hb with b18b1) I bought a set of for A EG HB but with this engine it looks like the trans.. is to close to the bar…
It is about the with of the lines above… is the a tie bar set up for a eg with swap… or will I have to custom make one or something…
Re: Need a sub fram fixed... and tie bar issues (tial-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tial-eg »</TD></TR><TR><TD CLASS="quote">OK first off.. I need some one close to Everett wa that can straiten out a sub frame and reinforce it … it is bent like 1 inch on the driver side…
i'd replaced the subframe otherthan try to repair it.
Re: Need a sub fram fixed... and tie bar issues (whitesi-94)
can you replace the sub fram where the rear lower controle armes go in to... is it not a unnabody subframe...
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tial-eg »</TD></TR><TR><TD CLASS="quote">can you replace the sub fram where the rear lower controle armes go in to... is it not a unnabody subframe... </TD></TR></TABLE>
The rear subframe is a separate piece that is spot-welded onto the unibody. Honda sells it separately. It can be removed and replaced.
Super Trooper
12
03-10-2007 03:56 PM
RzHybrid510
11-10-2004 11:10 AM
