Changing out my timing belt...what else should i change
Old Apr 19, 2006 | 12:11 PM
GSR_96814's Avatar
Default Changing out my timing belt...what else should i change
Here is what i have obtained:
OEM Tensioner
OEM Tensioner spring
OEM ITR water pump
OEM timing belt
I'm going to change out my w/p and timing belt soon...what else would you recommend changing out at the same time. ?
This is what i've come up with:
cam seals
air conditioner belt (squeaks)
I've also got a JDM Valve cover that I'll also install with new valve cover gaskets as well. I've already read through the T-I article, so any additional .02 is appreciated.
Old Apr 19, 2006 | 12:23 PM
Jay J's Avatar
Prince of Zamunda
Default Re: Changing out my timing belt...what else should i change (GSR_96814)
What about those small O rings????
Old Apr 19, 2006 | 12:43 PM
rgaray's Avatar
besides all the other acc. belts, maybe radiator hoses, thermostat, valve adjustment, plugs and wires.
Old Apr 19, 2006 | 12:53 PM
milano2kdc2's Avatar
Default Re: (rgaray)
+ fuel filter, oil, coolant
Old Apr 19, 2006 | 01:27 PM
AK94GSR's Avatar
Default Re: (milano2kdc2)
i would go ahead and change your crank seal and inspect the cam seals aswell. if they are leaking then go ahead and change them.
just pop them out with a small flathead screwdriver and put them back in with a large socket to make sure they go in flush
Old Apr 19, 2006 | 01:45 PM
DirtyBirdJR's Avatar
Default Re: (AK94GSR)
put some pulleys on it
Old Apr 19, 2006 | 07:08 PM
GSR_96814's Avatar
Default Re: (DirtyBirdJR)
Thanks guys. I'm going to take some of your folk's advice and also change out the crank seal, thermostat, plugs, coolant, fuel pump as well. Luckily I changed out most of the other stuff before...I know that my cam seals are worn out because of the leakage by the block...from previous experience would an OEM cam seal work best or an after market one? I read up that the aftermarket one has extra grooves...I was also going to buy the Toda Timing Belt, but I realised that Honda OEM products are in most cases better...
Old Apr 19, 2006 | 07:37 PM
Sack Master's Avatar
Default Re: (GSR_96814)
Might want to change all the o-rings for your vtec solenoid since you're doing all that as well.
Old Apr 20, 2006 | 08:09 AM
rgaray's Avatar
I dunno about the fuel pump, maybe the filter.
Old Apr 20, 2006 | 08:17 AM
GSR_96814's Avatar
I'm going to upgrade to the Walboro Fuel Pump...since turbo is down the line.
tiennhuynh
13
May 3, 2012 11:21 PM
TOO MUCH TORQUE
Apr 18, 2011 06:27 AM
zztrent
Honda Civic (2001 - 2005)
17
Oct 12, 2010 08:37 PM
thanh4o8
Aug 26, 2009 09:55 PM
arren123
Dec 11, 2003 09:46 PM
