Drag manifold Boost Creep ?'s please help
Old Apr 19, 2006 | 09:43 AM
D15Bbigred's Avatar
Default Drag manifold Boost Creep ?'s please help
i'm going to be buying a drag mani , but i've heard of all these boost creep issue's, is there a fix for this or is it something people deal with, or just buy a new manifold
Old Apr 19, 2006 | 10:02 AM
SynTeg's Avatar
It spikes with the Tial wastegate for some reason but with the deltagate wastegate it seems to be fine.
Old Apr 19, 2006 | 10:06 AM
Running925's Avatar
Default Re: (SynTeg)
i have a drag mani with a knock-off tial gate & had no problems with boost creep.. only problem that someone might run into is if they are running extreamly low boost with a huge turbo & a small wastegate, it wouldn't allow enough exhaust out, therefor causing it to creep coz it would continue to spool the turbo..
hih
Old Apr 19, 2006 | 10:08 AM
BoOsTeD C1's Avatar
I had the drag mani and tial wastegate setup and I didnt have any boost creeps at all...even with a manual boost controller held 10psi fine.My cousin also has the drag mani and deltagate setup no boost spikes for him.
Old Apr 19, 2006 | 10:46 AM
dpetro1's Avatar
Default Re: Drag manifold Boost Creep ?'s please help (D15Bbigred)
creep and spike are two different things. i was always under the impression that the drag mani was more prone to spiking due to wastegate placement. i never really heard of any creeping issues.
even the rumors of spiking have kind of been disproved for me too, there are so many people that actually run the manifold and have no problems. not saying it never happens or that its a good design, i just think people automatically write off the drag mani due to wastegate location.
Old Apr 19, 2006 | 11:23 AM
notoriousB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SynTeg &raquo;</TD></TR><TR><TD CLASS="quote">It spikes with the Tial wastegate for some reason but with the deltagate wastegate it seems to be fine.</TD></TR></TABLE>
I've never had a problem with spike or creep with my drag manifold and a tial 38mm wg.
Old Apr 19, 2006 | 11:24 AM
D15Bbigred's Avatar
thats what i'm starting too think, thnx for the answers so far, and ur right, i meant spike, either or i don't want em, i'm only goin to run a 5.63 psi spring and a t3 .42.48 turbo, hopefully it works out ok, but i'd love to here some other peoples opinions keep em coming
Old Apr 19, 2006 | 11:56 AM
fast2camciv's Avatar
i run the drag mani on my sohc...low boost is 7lbs and high is 15 and i have no spike or creep on either setting...all with a tial style gate and t3/t4
Old Apr 19, 2006 | 01:09 PM
D15Bbigred's Avatar
awesome i think i will be picking one up then
Old Jun 15, 2006 | 12:02 AM
hondaeg8's Avatar
Default Re: (D15Bbigred)
if you do get boost spike, will a MBC stop this?
Old Jun 15, 2006 | 04:43 AM
oscarmayer's Avatar
I woudl recommend porting the WG opening out to the size of your WG gasket, if it's bigger than 35mm. the stock mani comes with a 35mm and if you run a 38mm it needs to be opened up to 38mm gasket.
Old Jun 15, 2006 | 10:20 PM
jdmbb6-t's Avatar
i have a drag 2 mani with a tial 38mm that sits upside down......... and i have no issues to date.
Old Jun 16, 2006 | 11:52 AM
hondaeg8's Avatar
Default Re: (jdmbb6-t)
what do you mean sits up side down?
Old Jun 23, 2006 | 11:52 PM
boostedeghatch's Avatar
up
Old Jun 24, 2006 | 03:00 AM
rwcdrums's Avatar
I'm running the drag manifold with Tial 38mm. No creep or spike issues either. running 10lbs daily.
Old Jun 25, 2006 | 11:21 PM
Default Re: Drag manifold Boost Creep ?'s please help (rwcdrums)
where do you have your WG hooked up to?
Old Jun 25, 2006 | 11:47 PM
rwcdrums's Avatar
Default Re: Drag manifold Boost Creep ?'s please help (boostedeghatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedeghatch &raquo;</TD></TR><TR><TD CLASS="quote">where do you have your WG hooked up to?
Are you talking to me?
Old Jun 25, 2006 | 11:48 PM
yeah
Old Jun 26, 2006 | 09:21 AM
Urugly's Avatar
if the stock DRAG manifold is made for 35mm and you get like a tial at 38mm are you required to have it ported to 38mm??
or it wouldn't matter??
Old Jun 26, 2006 | 09:43 AM
rwcdrums's Avatar
Default Re: (Urugly)
I didn't have mine ported.
Old Jun 26, 2006 | 10:27 AM
oscarmayer's Avatar
yes you will need to port it out, or there's no point in having a 38mm.
Old Jun 26, 2006 | 10:33 AM
boostedcivicsir's Avatar
Mr. Badwrench
keep the 2.5 dp, i ran 17 psi for 2 years with no problems on my drag kit.
Old Jun 26, 2006 | 10:11 PM
sirguy01's Avatar
Default Re: Drag manifold Boost Creep ?'s please help (boostedcivicsir)
i had a drag and 38mm tial.. no problems at all.
Old Jun 26, 2006 | 10:55 PM
bigbadboy's Avatar
no problems here either. runs great no creep no spike
Old Jun 27, 2006 | 01:35 AM
Default Re: (bigbadboy)
damn, then why am i getting spike?
i have a 2.5" dp with 2.5" exhaust piping all the way back to the muffler.
no cat.
