need help with overheating problem
Old Apr 19, 2006 | 08:41 AM
streetsold6teeny8's Avatar
Default need help with overheating problem
my car overheats at idle only. the fans dont turn on but they work. in the fuse box the cooling fan fuse is fine, the cooling fan relay is brand new from honda, i changed the thermostatic switch and it still over heats at idle. I dont know what else it could be any idea appreciated thnks
Old Apr 20, 2006 | 01:04 AM
whitesi-94's Avatar
Default Re: need help with overheating problem (streetsold6teeny8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetsold6teeny8 &raquo;</TD></TR><TR><TD CLASS="quote">my car overheats at idle only. the fans dont turn on but they work. in the fuse box the cooling fan fuse is fine, the cooling fan relay is brand new from honda, i changed the thermostatic switch and it still over heats at idle. I dont know what else it could be any idea appreciated thnks</TD></TR></TABLE>
are u sure the radiator is good?
Old Apr 20, 2006 | 02:39 AM
bsixteen's Avatar
bump for this. i'm kinda having the same problem. while i'm driving my temps are fine but if i do some stop and go like in a drive thru line..my temps raise up..then i have to rev the car a little to make the temps go back down.
Old Apr 20, 2006 | 02:56 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (bsixteen)
I thought that said overEATING lol.
If your car only overheats at idle, check your thermo switch first. This is a two-pin sensor located right on the thermostat housing, or near it anyways. Also bleed the system of air. When the car is cold, start it and let it run with the radiator cap off. Let it idle for 20 min or so until the thermostat opens (both upper and lower hoses will be hot). Top off with coolant and close.
Old Apr 20, 2006 | 03:22 AM
kuja396's Avatar
Same thing with me too. Its completely fine when I'm cruiseing down the road but when I come to a stop for a couple of mins it overheats, I rev up the engine a litte and the temp drops back down to normal.
Old Apr 20, 2006 | 07:34 AM
BOOSTED RIVAL's Avatar
Default Re: need help with overheating problem (kuja396)
It could be your water pump that why it overheat then you rev your engine then the heat go back down . The water pump is not pumping fast enough to move the water to the radiator so you will have to rev the motor to spin the water pump fast to move the water to the radiator to cool it down. I think a bad water pump.
Old Apr 20, 2006 | 11:59 PM
bsixteen's Avatar
i got a brand new waterpump from honda put in my car probably less than a year ago so i don't think thats my problem
Old Apr 21, 2006 | 10:10 AM
-Gary-'s Avatar
Did you bleed all of the air form the system?
Old Apr 21, 2006 | 10:21 AM
allanonjj's Avatar
To the thread starter:
If you are sure that the fan works (checked it with 12v), You could do like I did. I went to Auto Zone and bought a thermostatic fan switch. It was only like 20 bucks or so. It turns the fan on when the thermostat (included) reaches a pre-determined temp. You can set this temp at whatever youd like.... thats why I put it on mine. I like for the fan to come on a little earlier,.... and when we are at the track, I'll set it to stay on. That way between runs the fan cools down the engine.
Old Apr 24, 2006 | 05:56 PM
yea my fan does turn on and i switched and put a new thermostatic switch and it still overheated. both the cooling fan relay and fuse are fine. I heard thought tht there is a relay behind the passenger headlight which was the relay for the motor. im not sure on that. ill probably do tht and buy the thermostatic switch you're telling me about. Thnks
nelson0616
Nov 16, 2016 11:36 AM
Danine
Apr 7, 2014 07:08 PM
03element
Honda CR-V & Element
Mar 18, 2014 04:53 PM
-Championship-
Nov 14, 2006 10:38 AM
harveyy
17
Mar 1, 2006 04:32 AM
