Energy suspension CRX 91' Q. ?
I did a search but can't find anything usefull
The thing is that I want to replace all bushings on my CRX, so I'll buy master kit, but I know that master kit doesn't include everything that ES offer for CRX
I heard that this parts are also available:
"Rear trailing arms,Rear compensator arms,Rear upper arms,Rear sway bars-this is not in a base kit i believe –rear end control arm bushing set ES30, ESsway bar"
For trailer arms there's no problem finding part # but for other I can find those on their site, so I'm asking if anyone know part # of those parts and is there anything else beside those, so I'll have full suspension bushings replaced
Thanks for helping me out
P.S.: did e-mail the ES but it's takin' them a while to answer
about the part #
about the part #
The compensator arm bushings, trailing arm bushings, and rear upper control arm bushings, if I recall correctly are the ones not included with the ES master kit.... At the time, I found the Prothane ones easily so I ordered those. The rear sway bar isn't included either, but at the time I picked up a Suspension Techniques rear bar, which included all the bushings anyway.
Oh, and while you're at it- since it's pretty time consuming anyway- I'd suggest springing for the motor mount inserts as well. I've ridden in a few crx's with and without them- I'm _really_ glad I got them- completely firms up the engine- little to no surging under hard acceleration or hard braking- and for autocross this is a wonderful thing. Oh - however - ES suggests using these inserts ONLY with brand new motor mounts. If you were to put them in older, worn out mounts, well - I could see the rubber probably tearing apart.
I'll try to find those part numbers for you...
Thanks for help,
about motor mounts no need for them cause I got hasport's(track) in and I'm very happy with those, they do their job fine
Why I want to replace all bushings, cause I'll go to track a lot and want to have suspension as good as it can be...
Right now I have all suspension part in my garage and ready to be sanded and powder coated and then I'll put in all new bushings
So beside those bushing I'll change crossmember and rear lower arms too, all parts that can be replaced with better parts
ED9man
45
Mar 15, 2006 11:49 AM
SPiFF
49
Mar 26, 2003 04:26 AM
