Can I use Stock Lugnuts on Aftermarket Wheels?
Old Apr 7, 2002 | 03:27 PM
CPR's Avatar
CPR
Default Can I use Stock Lugnuts on Aftermarket Wheels?
I just read that it's not advisable to use aftermarket lugnuts on stock wheels. So i'm wondering if the opposite holds true. I'm waiting on a set of Kyokugen lugs to arrive this week. The lugnuts that came with my Kosei K1's did not have a wheel lock so I decided to use the stock lugs. Are my wheels going to fall off???
Old Apr 7, 2002 | 03:47 PM
Cosworth's Avatar
Default Re: Can I use Stock Lugnuts on Aftermarket Wheels? (CPR)
The basic rule is:
1. Thread pitch needs to be correct. (xxx x 1.25mm or xxx. 1.50mm)
2. The seating surface has to be the same (as the wheel). (eg. acorn, tapered, etc.)
I've had wheels that would accept stock Honda lugs (acorn type)... some other wheels I've had to get tapered lugs. Just don't expect your OE lugs or aftermarket lugs to accomodate all types of wheel manufacturers.
Old Apr 7, 2002 | 03:55 PM
CPR's Avatar
CPR
Default Re: Can I use Stock Lugnuts on Aftermarket Wheels? (Cosworth)
Thanks Cosworth but I have no idea as to what you're referring to when talking about acorn/tapered and seating and...well, everything you posted. lol Care to explain more what you mean? Thanks
Old Apr 7, 2002 | 04:06 PM
py1188's Avatar
Basically, NO
Oem wheels have an acorn seat requiring an acorn (OEM) lug. Most aftermarket wheels require tapered lugs. Thus, they are not interchangeable.
Old Apr 7, 2002 | 05:01 PM
Cosworth's Avatar
CPR:
Old Apr 7, 2002 | 06:40 PM
nsxtcjr's Avatar
New User
Great diagram. Looks like yoshi's not the only artist around here...
The diagram shows the difference between the "seating surface" of the lug nuts, the surface that comes in contact with the wheel as you screw them on. If you look at the wheels when they're off the car, you'll see that the surface of the wheel where the lugs come into contact will match one type of lug nut - either it will be a concave curve to match the acorn-shaped nuts, or it will be perfectly conical to match the conical nuts.
[Modified by nsxtcjr, 9:43 PM 4/7/2002]
Old Apr 7, 2002 | 07:51 PM
CPR's Avatar
CPR
Default Re: Can I use Stock Lugnuts on Aftermarket Wheels? (nsxtcjr)
Ok, so it's a given I need to get my stock lugs off my car but I won't be able to do it until tomorrow night. What are the consequences of using the wrong lugnuts? Will I ruin the wheel, mounting bolts, the car??? Someone school me
Old Apr 7, 2002 | 08:06 PM
Ochux's Avatar
New User
Does anyone know where I can purchase a set of stock lug nuts for cheap. The dealership wants $7.50 a lug nut!!!! Crazy right......LOL
Old Apr 7, 2002 | 08:20 PM
VADE-R's Avatar
New User
Default Re: Can I use Stock Lugnuts on Aftermarket Wheels? (Ochux)
i'm also looking for the acorn (OE) type nuts but in black, does anybody know where i can get this item, and maybe not at 7 bucks apiece.....thanks
Old Apr 7, 2002 | 08:31 PM
Wet Nudl's Avatar
New User
No need to get OEM lugs. Just go to pep boys and get some that will fit Integra. They work fine and a pack of four is like $2.00
Old Apr 7, 2002 | 09:55 PM
Toda Party's Avatar
Default Re: Can I use Stock Lugnuts on Aftermarket Wheels? (VADE-R)
PAINT EM!
VHT black paint works good, but probably will need a new coat every couple times u loosed/torque em down
Petah
Jun 3, 2010 08:00 AM
killerpenguin21
Jan 9, 2009 03:40 PM
johng
10
Nov 6, 2002 08:28 PM
Mikeveli
10
May 25, 2002 06:44 PM
OohOoh
Feb 28, 2002 08:33 PM
