real quick question....ek swap?
Old Apr 18, 2006 | 11:35 PM
atmosphere's Avatar
Default real quick question....ek swap?
for ek swap....97 hx dropin jdm gsr...
all i need is integra mounts? and all set or? its from a 99gsr
or do i need integra mounts and si driver side and rear tranny? mount? or bracket?
thanks all.
Old Apr 19, 2006 | 12:46 AM
BlueIntegraBoy's Avatar
Default Re: real quick question....ek swap? (atmosphere)
Driver side - Use driver side mount bracket from the 99-00 Si: 11910-P30-000. This piece bolts to the block below the cam gears. Reuse the civic studs. Also, use all other civic parts at this location.
Rear tranny - Use rear tranny mount from the 99-00 Si: 50827-S04-N10. Use the stock civic rubber mount.
AC Bracket - Use the ac bracket from CRV: 38930-P7J-000, and reuse the civic stud and rubber mount. Integra piece is similar but won't work.
Front tranny bracket - Use integra piece on the tranny but civic stud and rubber mount. Integra stud and rubber looks the same but won't work.
Upper tranny mount - Use all the civic pieces.
http://phear7imports.net/trey/6gen
Old Apr 19, 2006 | 12:54 AM
4dohs4mohoes's Avatar
Default Re: real quick question....ek swap? (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Driver side - Use driver side mount bracket from the 99-00 Si: 11910-P30-000. This piece bolts to the block below the cam gears. Reuse the civic studs. Also, use all other civic parts at this location.
http://phear7imports.net/trey/6gen</TD></TR></TABLE>
WOW! If those are all Honda part #s, that's wonderful info to have.
Old Apr 19, 2006 | 02:30 PM
atmosphere's Avatar
dude you are so ******* amazing. thanks.
Zx
Dec 13, 2006 07:53 AM
pinoyboy204
10
Apr 26, 2006 10:09 AM
siffredi
Apr 19, 2006 05:39 PM
b20ek
Jun 28, 2003 12:40 PM
delacampos
Jan 27, 2003 06:22 AM
