B-series Tranny's?
Old Apr 18, 2006 | 09:41 PM
94teggieGSR's Avatar
Default B-series Tranny's?
What b-series tranny's work well with a 94 gsr motor, other than the gsr tranny?
Old Apr 18, 2006 | 09:46 PM
VHOA's Avatar
Default Re: B-series Tranny's? (94teggieGSR)
any b series tranny will work with your gsr including a si tranny or a ls tranny or a type r tranny
Old Apr 18, 2006 | 09:48 PM
dvp's Avatar
dvp
Generally people like the Civic si or the Type R tranny. Same low gearing but the R has an LSD.
Old Apr 18, 2006 | 10:12 PM
What tranny is the better performance wise?
Old Apr 18, 2006 | 10:13 PM
to have the lsd the tranny must be jdm right? so i can get a jdm b16 tranny and have a lsd?
Old Apr 18, 2006 | 11:01 PM
foam's Avatar
Only Type R's come with LSD. You can install LSD into a tranny if you want though.
Old Apr 19, 2006 | 07:35 AM
ne body know where i can get a new transmission for cheap a site or place in sactown, cali?
Old Apr 19, 2006 | 07:41 AM
JETSPD1477's Avatar
LS tranny is a dog on a vtec motor unless you're boosting. stick with a vtec tranny and be happy.
Old Apr 19, 2006 | 07:44 AM
Lan's Avatar
Lan
Default Re: (94teggieGSR)
Attarco.... Go with b16 or type r if you can find one.
Old Apr 19, 2006 | 03:48 PM
thanx guys
Old Apr 19, 2006 | 03:58 PM
Dogginator's Avatar
Daisy... Daisy...
Here is some information:
http://tech.hybridgarage.com/tech/bseries.html
Old Apr 21, 2006 | 07:22 AM
Default Re: B-series Tranny's? (Dogginator)
So, the higher the ratios the better? So, the b16a6 (98+ civic si tranny) is a better transmission than the usdm dc2 gsr transmission?
Old Apr 21, 2006 | 07:43 AM
CleanLikeJdm's Avatar
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94teggieGSR &raquo;</TD></TR><TR><TD CLASS="quote">So, the higher the ratios the better? So, the b16a6 (98+ civic si tranny) is a better transmission than the usdm dc2 gsr transmission?</TD></TR></TABLE>
Better in what way though, shorter gearing maybe, what kind of setup is it even going on?
And do you like acceleration better then gas mileage?
Like someone said before though, LS &gt; GSR &gt; B16 &gt; Type-R
In terms of shorter gearing, plus b16, & type-r are the same except for the type-r having lsd.
Old Apr 21, 2006 | 08:35 AM
JThrasher79's Avatar
Default Re: B-series Tranny's? (FlatBlackTeg)
i have a jdm b16 sir trans and it has lsd..
Old Apr 21, 2006 | 08:39 AM
Hype-R Stalker
Default Re: B-series Tranny's? (JThrasher79)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JThrasher79 &raquo;</TD></TR><TR><TD CLASS="quote">i have a jdm b16 sir trans and it has lsd.. </TD></TR></TABLE>
I only meant USDM trannys if you were referring to my post.
Old Apr 21, 2006 | 09:26 AM
petergriffen's Avatar
get a type-r tranny and take the 5th gear out of you gsr . 5th is shorter in the gsr than it is on the type-r
Old Apr 21, 2006 | 04:07 PM
bump
Old Apr 21, 2006 | 06:02 PM
VHOA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94teggieGSR &raquo;</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
are you serious? You didnt get enough info from all that what else do you want to know? Do you want some to go with you to go pick up the tranny with you or somethin?
Old Apr 21, 2006 | 07:14 PM
Hype-R Stalker
Default Re: (VHOA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VHOA &raquo;</TD></TR><TR><TD CLASS="quote">are you serious? You didnt get enough info from all that what else do you want to know? Do you want some to go with you to go pick up the tranny with you or somethin?</TD></TR></TABLE>
probably.
Old Apr 21, 2006 | 08:33 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: (FlatBlackTeg)
Buy my OEM LSD and you will have LSD without having to buy a new tranny.
Old Apr 23, 2006 | 06:49 PM
If you put a Stage 2 pressure plate w/ a Ceramic 6 puck sprung disc from Competition Clutch on the stock tranny, will the transmission start failing? Some friend of mine said that, because its a race clutch kit. if you drive it relular eventually the tranny will start failing, he said you have to be racing with it almost all the time.
Old Apr 23, 2006 | 07:49 PM
bump
Old Apr 23, 2006 | 09:47 PM
HT Black OPs
Your friend is wrong. As long as you follow the manf. rules on how to break the clutch in, it should be fine for DD.
Old Apr 24, 2006 | 11:13 PM
thanks man
Old Apr 25, 2006 | 01:19 PM
Bense's Avatar
everything you'd ever want to know is in my sig
jdmgeezer
Feb 20, 2008 03:35 PM
rdwaldo
16
Mar 23, 2007 06:08 PM
MurdersV8s
Jul 19, 2006 03:36 PM
John221
May 23, 2006 09:40 PM
Cornbread Jr.
Oct 31, 2003 09:46 AM
