Oil Leak Problem
Old Apr 18, 2006 | 09:05 PM
NA EJ8's Avatar
Default Oil Leak Problem
Hey need some help. I have a ls/vtec with high compression and I have an oil leak from my pan. Have changed the pan twice with same results. any help would be appreciated. I was thinking of putting the moroso pan on but not sure if it would help. thanks in advance.
Old Apr 18, 2006 | 09:49 PM
nocturnaldragon's Avatar
Default Re: Oil Leak Problem (NA EJ8)
Did you clean the seal properly both times?
Old Apr 18, 2006 | 10:01 PM
coupedragracing's Avatar
yea definitly make sure to check and clean the seal properly. had same problem with my friends ls.
Old Apr 19, 2006 | 05:28 AM
NA EJ8's Avatar
Default Re: (coupedragracing)
yeah me and my friend did everything like your supposed to both times hes a tech so he did it the second time n it still leaks.
Old Apr 19, 2006 | 07:33 AM
AnR5I0's Avatar
where exactly is it leaking from your oil pan.. crankshaft seal or your oil plug .. if it leaks from the head change out the camshaft seal.. probably from your valve cover .. let me kno and ill give u more details.. lates
Old Apr 19, 2006 | 07:35 AM
AnR5I0's Avatar
as its leaking from your oil pan, your oil pan might have a crack on it.. or probably the pan isn't tight enough.. just take it off and put some hondabond on it and put the pan back on make sure its tight enough..simple problem
Old Apr 19, 2006 | 10:56 AM
NA EJ8's Avatar
Default Re: Oil Leak Problem (AnR5I0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnR5I0 &raquo;</TD></TR><TR><TD CLASS="quote">as its leaking from your oil pan, your oil pan might have a crack on it.. or probably the pan isn't tight enough.. just take it off and put some hondabond on it and put the pan back on make sure its tight enough..simple problem</TD></TR></TABLE>
did that still leaking no cracks pan is new
da9blk1
Dec 7, 2008 09:48 AM
touandcim
Feb 22, 2008 08:58 PM
6E LUDE
Oct 19, 2005 06:23 PM
Btothe3rdDegree
27
Sep 6, 2003 07:03 PM
johnzm
Sep 30, 2002 02:46 PM
