Suspension & Brakes Theory, alignment, spring rates....
94 integra brakes to 96 civic
Old Apr 18, 2006 | 08:56 PM
VRD^don's Avatar
Default 94 integra brakes to 96 civic
okay i just pick up a junked 94 teg..still has everythin on it..i want to swap brakes over to a 96 civic hatch..i was wondeing if i can use the 94 teg front lower control arms cause i want to use the sways as well...was wondering if the sways will fit..havent tried it yet so help me out guys..
Old Apr 19, 2006 | 10:31 AM
VRD^don's Avatar
Default Re: 94 integra brakes to 96 civic (option_2)
help
Old Apr 19, 2006 | 02:49 PM
Voyage34's Avatar
i want to say the fron bar will bolt up without swapping the front lca's but im not positive. i think the only time you would need to swap front lcas is if youre putting in a 99-00 si 26mm bar.
the rear bar fits, you just need to make sure you have the proper mounting brackets, there is a thread with a picture somewhere on here, ill see if i can find it.
the trailing arms will swap over if you dont feel like taking the brake assembly off the trailiing arm, its supposed to be a bitch and a half to get off. swapping the rta/brake assemblies will be fine.
Old Apr 20, 2006 | 02:17 PM
96hatch96's Avatar
Isn't the 94 teg lower control arm the same as the 96-00 civics? I have the 95 ls fronts on my 96 civic and the LCA's are the same.
Old Apr 20, 2006 | 02:46 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (96hatch96)
The front LCAs will fit. You do need them if you don't already have a front swaybar. The front will also fit, but I don't think the mounting hardware (that holds the bar to the chassis) is the same. You may need just those metal U shapped parts from a 96-00 civic.
The rear brakes & brake hoses will fit. The e-brake cables may not fit. You will have to research that one. You will need the larger Integra master cylinder & brake booster to make the front brakes work properly. If the brake hard-lines coming out of the MC are not identicle on both cars, you should sell the integra MC/BB & buy a 15/16" or 1" master cylinder that matches your cars existing brake booster & brake lines. It will be much easier than bending & flaring the hard lines to meet the new parts...
Old Apr 20, 2006 | 02:58 PM
VRD^don's Avatar
Default Re: (94eg!)
cool..thanks alot..yeah i have the whole integra chassis at my place right now so i can always take things off it..
sleepyaccord96
Jun 12, 2013 10:53 AM
94hbdx
Jun 19, 2011 10:28 AM
Steven.
Jul 27, 2008 08:45 AM
mini-cRx
Oct 28, 2004 05:34 PM
whitelightning
Jun 20, 2002 06:12 AM
