EF engine mounts in DA?
I am fairly certain they won't. Any B-series engine you want to drop in a DA, you just use your stock DA mounts. If you are going 250+whp you may want to look into Innovative Mounts poly kits.
thank you very much it kinda sucks though cuz last night i ordered energy suspension inserts but they were only 20 buck so not that bad but ill probably use the inserts anyways since my mounts have seen much abuse for almost two years now
if we are talkin about bseries driverside mount, yes it will fit 90-91 da...
my driverside mount was fucked and i left it till the stud and the screw on the bracket came off and snapped in half...i got the mounts and brackets from my donor 89 civic hatch that had a b16 swap.
please...dont contradict..
91EF_Si
Sep 6, 2007 08:01 PM
BseriesHatch
Feb 27, 2004 01:25 PM
