Rear trailing arms?
Old Apr 18, 2006 | 07:01 PM
94teggieGSR's Avatar
Default Rear trailing arms?
Do you guys know, if JDM type R rear trailing arms can go on my 1994 Acura integra gsr usdm chasis?
Old Apr 18, 2006 | 07:13 PM
ITR#132's Avatar
Default Re: Rear trailing arms? (94teggieGSR)
yes
Old Apr 18, 2006 | 07:22 PM
.brian.'s Avatar
Default Re: Rear trailing arms? (ITR#132)
edited
Modified by .brian. at 11:35 PM 4/18/2006
Old Apr 18, 2006 | 07:26 PM
BlueIntegraBoy's Avatar
Default Re: Rear trailing arms? (.brian.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .brian. &raquo;</TD></TR><TR><TD CLASS="quote">wouldn't he need type r shocks as well?</TD></TR></TABLE>
Only if using ITR LCAs
Old Apr 18, 2006 | 07:35 PM
.brian.'s Avatar
Default Re: Rear trailing arms? (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
Only if using ITR LCAs</TD></TR></TABLE>reading &gt; me
Old Apr 18, 2006 | 07:42 PM
So, do they fit or not?
and what does AS IS mean?
here's the link, http://passwordjdm.com/product...D=216
Old Apr 18, 2006 | 07:48 PM
.brian.'s Avatar
Default Re: (94teggieGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94teggieGSR &raquo;</TD></TR><TR><TD CLASS="quote">So, do they fit or not?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR#132 &raquo;</TD></TR><TR><TD CLASS="quote">yes</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94teggieGSR &raquo;</TD></TR><TR><TD CLASS="quote"> what does AS IS mean?</TD></TR></TABLE>
No returns or exchanges. It may have some rust and/or worn bushings, etc.
Old Apr 18, 2006 | 07:53 PM
So that **** should fit. What do you think, should i get a new or old pair? Do the old ones look like they in good shape?
new=100
old=50
Old Apr 18, 2006 | 09:41 PM
dvp's Avatar
dvp
Your link shows the rear LCA's not the trailing arms....
The LCA will fit but you will need different shocks for the rear....the Rear trailing arms will have a 5 lug hub on them.
Old Apr 21, 2006 | 07:28 AM
Will these fit on my 1994 acura integra gsr or would i have to do some modifications?
http://www.jhpusa.com/catalog/...d=840
Old Apr 21, 2006 | 07:30 AM
.brian.'s Avatar
why do you want type r LCA's so bad? just get something like omni and call it a day.
Old Apr 21, 2006 | 07:31 AM
JETSPD1477's Avatar
they will fit but you have to use different rear shocks
Old Apr 21, 2006 | 07:36 AM
Default Re: (.brian.)
no its because mines, the bushings on them are shot up and i thought the type r ones would fit but i guess u have to change up the suspensiona nd im not going to do that, ill probably go to a dismantler and get some fairly new ones or where can i find those omni lca's?
Old Apr 21, 2006 | 07:42 AM
JETSPD1477's Avatar
http://www.passwordjdm.com/pro...D=277
Old Apr 21, 2006 | 07:46 AM
thanx man
Tyson
Suspension & Brakes
19
Sep 23, 2012 09:44 PM
blazin415
Suspension & Brakes
10
Sep 17, 2007 12:24 PM
BLANCOh22a4
Feb 13, 2007 05:50 AM
. o 69 o .
Sep 9, 2003 06:03 PM
typeee
May 6, 2003 10:48 AM
