Rear Disc Brakes (Searched)
Old Apr 18, 2006 | 06:37 PM
ecl-ricochet's Avatar
Default Rear Disc Brakes (Searched)
Yea I picked up this rear disc swap a few months ago and now that my d15b swap is done I guess I should tackle this.(my shoes are squeaking anyway...too many yanks of the e-brake ) But I got a quesiton. I think the swap I got was from a 93 teg...but everything appears that it should bolt right into place on my 95 hatch. All the things I have read only speak about 94-01 tegs. Any thoughts on this one? And the LCA's are all ready for a sway bar so is it ok to use these teg LCA's? Do you think that I should just pick up some omni's instead or another brand? And should I use 92-95 SI E-Brake Cables or 2 door teg? Thanks a lot.
Old Apr 18, 2006 | 07:08 PM
BlueIntegraBoy's Avatar
Default Re: Rear Disc Brakes (ecl-ricochet)
The trailing arms will bolt up. Make sure you use the Civic toe arm and the Civic upper control arm. I heard the DA LCA will bolt up, you can try it since you have it. Kteller is selling Omni LCAs for $100 shipped (well to Hawaii that is, may be cheaper). I think the ebrake cable will work from the DA, if it doesn't, 92-95 Si cables will work.
Old Apr 18, 2006 | 08:42 PM
Dstretch33's Avatar
you can just bolt up the rear disc, you do not have to replace anything unless you want to. all the Lcas dictate is what suspensions ans sways u will run. I had omni's on my Si, they are nice quality....no complaints.
solidinside
Jul 29, 2007 01:40 AM
Loserkidwac
Mar 3, 2007 09:57 AM
ED3_FTW
Dec 16, 2006 04:32 PM
bugster
10
Aug 16, 2006 06:19 PM
Do_Ster
Feb 11, 2004 02:44 PM
