:special delivery: B-series Mid plate : hotrod civic install :
whats goin on everyone ?
a small update on my friends hotrod coupe AKA Guinea pig. we(2.0coupe, myself, our ladys, and our friend jamison) were @ the track about 1.5weeks ago. (sunday) and broke a tab off of our trans, the car wouldnt go into gear
monday came around and we were on a mission. place a few calls. im'd a few people on h-t and noone could come through on time. i guess if you want it done, you have to do it yourself.
sooooo............
we went and bought these 2 36x12x1/4inch plates from http://www.vpracecars.com, 4 link mounting brackets, and also got some cardboard/oaktag from them.
we mocked the plate up, cut it from the cardboard/oaktag. took it to http://www.JMfabrications.com . jimmy was cool enough to let us use his bandsaw to cut out our plates with. we also used his drill press/bits/center punchs/ markers. etc. he also milled down our trans case 1/4inch with his new cnc machine.
i had a friend (hondacivicsir1) machine me a length of solid steel for dowl pins@ his day job. we then cut the dowl's to be a 1/4inch longer than stock so they would fit into the engine plate and trans.
also, we had a vinal graphics guy come out and check the car. we are getting stickers made up, they should be done this week sometime.
here are some pics of it.
this is the plate for my car(this is not the same plate as the one in the rest of the pics. but is identical.)
the rear mounting location. dont mind them SICK xrp hose's
the front mounting location
the milled case
the G-force/long shifter. in this picture you can also see the staging brake/line lock and the NLR boost control. the silver bottle in the front is for the fire supression system
an overall shot.
Modified by Dturbocivic at 10:51 PM 4/18/2006
monday came around and we were on a mission. place a few calls. im'd a few people on h-t and noone could come through on time. i guess if you want it done, you have to do it yourself. sooooo............
the milled case
an overall shot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daveG »</TD></TR><TR><TD CLASS="quote">Damn. Good stuff.
Now get the hatch goin!
very soon, im gettting it done this year, i promise
</TD></TR></TABLE>very soon, im gettting it done this year, i promise
Dave what tab was broken of the trans? Did it keep it from going in every gear? I hope to see the car run Thursday.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorhatch »</TD></TR><TR><TD CLASS="quote">Dave what tab was broken of the trans? Did it keep it from going in every gear? I hope to see the car run Thursday.</TD></TR></TABLE>
it was the rear "19mm" top bolt. wouldnt go into 2nd or 4th. either the shifter mount got tweaked from the engine getting moved or the shifter rod got bent slightly.
i honestly dont know if the trans broke from the bolt being loose or we just had a bad design on it the 1st time around.
Curious, what are you using the "full throttle" switches on the shifter for? Ignition interupt for clutchless shifting?
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 »</TD></TR><TR><TD CLASS="quote">I love this car. I wanna see this thing in person soon! </TD></TR></TABLE>
x2
x2
yo don't forget to tell merman to put the "PAY BACK" sticker on lol good **** as always and if you need me to do any thing let me know and how did frosty the snowman work out?
plate is a sucess the driver crash gears beatifuly last night
the car went 9.050 shuting off. 1st pass off the trailor
2nd pass 9.15 @ 125 shut off
license pass's complete.
SMOOTHN
Jun 10, 2006 04:18 PM
