Del Sol radiator question for b series motor
For what reason are you going to do this? There was no automatic Del Sol w/ a B-series engine. The B16A Del Sol was always 5-spd and doesn't have the core for the auto. trans. fluid. If you found a half-radiator w/ nipples for the ATF they aren't going to be in the same spot - you could get longer rubber lines to make it work though. Then you're going to have problems w/ the radiator hose diameter.
the soL that could
12
Mar 25, 2006 03:58 AM
