Car doesn't want to turn over
Old Apr 18, 2006 | 05:11 PM
Ag3nt_Orang3's Avatar
Default Car doesn't want to turn over
Well I am back to square one again. I just installed some TODA valvetrain and got everything bolted in. Timing is fine when it comes to ignition and cams. Distributor and spark plugs are working. I have fuel, but it will not turn over. I am throwing no codes. Plenty of oil and all that good stuff. What am I looking at?
Turn ignition into the on position, I hear the fuel pump turn on. Checked fuses and everything is ok...I am corn-fused...
Old Apr 18, 2006 | 05:47 PM
Default Re: Car doesn't want to turn over (Ag3nt_Orang3)
bump...had someone try to start the car and found that my fuel pressure guage is going up and down very rapidly from 60-40. Would this be a faulty FPR? Still no turn over
Modified by Ag3nt_Orang3 at 8:39 PM 4/18/2006
Old Apr 18, 2006 | 06:10 PM
schardbody's Avatar
you mean it wont crank up or the motor wont spin over??? very confusing post, cuz you say wont turn over then you say you had someone crank it???
Old Apr 18, 2006 | 06:17 PM
Default Re: (schardbody)
Turn over. Everything turns, but it won't start up.
Old Apr 18, 2006 | 06:49 PM
99EeeKay's Avatar
Default Re: (Ag3nt_Orang3)
this happeed to me, recheck your timing... i had it to where the cam gears were perfect. but the crank gear was one knoth off... i found out by taking the whole assy apart and noticing it... to check maybe take out the spark plug in cyl 1 and put something in there. like an antannea or something. and turn the crank until its at TDC... and then look if the cam gear marks are still lining up.
Old Apr 18, 2006 | 08:58 PM
redhondacivic's Avatar
Have you done a compression or leakdown test?
Old Apr 18, 2006 | 09:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redhondacivic &raquo;</TD></TR><TR><TD CLASS="quote">Have you done a compression or leakdown test?</TD></TR></TABLE>
Have not yet
jimmy051702
Aug 25, 2011 04:43 PM
whytry2002
Oct 19, 2010 08:44 PM
GreenGoblinEF
17
Feb 28, 2010 03:00 PM
mygfs92lx
Jul 19, 2006 06:33 PM
flip1199
Feb 21, 2005 03:52 PM
