axle nut broken
Old Apr 18, 2006 | 04:58 PM
italstallion's Avatar
Default axle nut broken
hey guys im almost finished my swap and i got my river side axle out and now the passenger is being gay the person who did axles last punched the tab in way too far so in my attempt to remove them they became embedded in the spline and i cant remove the nut ,i just broke my 1/2 drive ratchet on it .i tried jumping on my breaker bar(it can fully support me up) ive tried chisseling the tab out,ive tried heating it up with a propane torch and no luck....air air tools a must here or is there some sneaky way i can do this.
Old Apr 19, 2006 | 01:26 PM
anyone??
Old Apr 19, 2006 | 01:29 PM
Schrader's Avatar
Get a bigger Breaker bar...
Other then that, there is no substitute for a good impact
Old Apr 20, 2006 | 06:50 PM
ok i used the 1/2 electric impact and it didnt work im thinking of removing the whole hub so i can bring it to a shop what would i have to take out lower balljoint,upper control arm,caliper.... what else
Old Apr 20, 2006 | 10:16 PM
professor poon's Avatar
1) put Liquid Wrench or similar lubrication product on axle nut.
2) buy a 2 ft. CRAFTSMAN non-ratchet breaker bar
3)Go to home depot, buy a 5 ft. steel pipe (the one with the orange plastic covers on the ends that's about 11 bucks)
4) stand on the end of it and hop lightly
5) optional. break your breaker bar and go back to sears where they will replace it for free. I doubt this will happen because I put about 800lb/ft onto my breaker bar using that^ strategy and the thing didn't break.
6) Succeed
7) Do the dance that "aallbbeerrtttttt"'s avatar is doing
Old Apr 20, 2006 | 11:10 PM
TylerB's Avatar
Default Re: axle nut broken (italstallion)
I've had the same problem, here's how i did it.
1" drive + 32mm impact + 8ft steel pipe + my fat *** =
I didnt really have a problem breaking it loose, I'm 6'5" 240lbs.
slow_low_eddie
May 5, 2014 01:26 PM
hondaboy9506
34
Nov 1, 2010 05:50 AM
SoTexDC2
Jun 22, 2007 06:05 PM
JeremyL
May 2, 2005 06:57 PM
400whp
Jul 10, 2003 11:55 AM
