How to tell the difference between a JDM B16 92-93 XSi Swap and all other JDM B16's???
Old Apr 18, 2006 | 04:57 PM
92integraVTECgsr's Avatar
Default How to tell the difference between a JDM B16 92-93 XSi Swap and all other JDM B16's???
I ordered a JDM B16 92-93 XSi Swap from HMO. It it OBD1 and has 170hp where as all others have 160hp.
How can I tell the difference or know that I got the 170hp engine instead of the 160hp engine?
Old Apr 18, 2006 | 07:31 PM
Default Re: How to tell the difference between a JDM B16 92-93 XSi Swap and all other JDM B16's??? (92integr
bump
Old Apr 18, 2006 | 11:06 PM
BlueIntegraBoy's Avatar
Comes with a YS1 tranny as opposed to a Y1 tranny. Comes with a PR3 ECU as opposed to a PW0 ECU.
Old Apr 18, 2006 | 11:13 PM
vtecrazy's Avatar
also if it has the original rocker cover on it. The newer B16A's (B16A2 and B16A3) have DOHC VTEC written in a different way to B16A1's,
Old Apr 18, 2006 | 11:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Comes with a YS1 tranny as opposed to a Y1 tranny. Comes with a PR3 ECU as opposed to a PW0 ECU.</TD></TR></TABLE>
The YS1 is non LSD right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecrazy &raquo;</TD></TR><TR><TD CLASS="quote">also if it has the original rocker cover on it. The newer B16A's (B16A2 and B16A3) have DOHC VTEC written in a different way to B16A1's, </TD></TR></TABLE>
what do u mean by rocker cover?
Old Apr 18, 2006 | 11:19 PM
vtecrazy's Avatar
Rocker cover = cover thats on top of your head, must be my New Zealand accent
Old Apr 18, 2006 | 11:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr &raquo;</TD></TR><TR><TD CLASS="quote">
It comes with optional LSD. It has the shortest stock first gear out of all B-series trannies.
Old Apr 18, 2006 | 11:22 PM
vtecrazy's Avatar
Old Apr 18, 2006 | 11:24 PM
vtecrazy's Avatar
whoops im becoming a double posting *****
Old Apr 19, 2006 | 07:30 AM
JETSPD1477's Avatar
hmmm... valve cover has BIG vtec, spray bars are extruded instead of cast, vtec solenoid is the smaller one... i know those parts can be swapped but you cant do much other than taking off the head to see if you have P30 pistons in there.
Old Apr 19, 2006 | 07:34 AM
92TypeR's Avatar
FSAE
Default Re: (JETSPD1477)
My '92xsi b16a came with an OBD1 PR3, which is the biggest indicator.
Old Apr 19, 2006 | 07:58 AM
mike-y's Avatar
it should also have the grey plugs on the wiring harness, instead of the milky white ones. and if you are lucky, the YS1 trans will come with an LSD
Old Apr 19, 2006 | 09:15 AM
no unfortunately HMO didn't have any LSD transmissions in stock when i order. I waited 2.5 weeks and still nothing.. so i had to order a non-lsd trans. sucks big time.. but oh well.
Old Apr 19, 2006 | 12:30 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr &raquo;</TD></TR><TR><TD CLASS="quote">I ordered a JDM B16 92-93 XSi Swap from HMO. It it OBD1 and has 170hp where as all others have 160hp.
How can I tell the difference or know that I got the 170hp engine instead of the 160hp engine?</TD></TR></TABLE>
obd1. if its obd1+ then its the 170hp and 113tq b16,.
Crackback
11
Aug 17, 2006 09:44 PM
92integraVTECgsr
Apr 3, 2006 01:25 PM
Zatzy
26
Jul 27, 2005 03:08 PM
kaj
Dec 8, 2004 11:14 AM
yellowmonkeyboy
Aug 26, 2003 11:16 PM
