Tinking, crackling, chattering noise from my B16A..Help
Old Apr 18, 2006 | 03:43 PM
mikeunreal2's Avatar
Default Tinking, crackling, chattering noise from my B16A..Help
I believe my valves need to be adjusted/timed. I hear a crackling/tinking noise coming from my engine when it idles and is under acceleration, pretty much any time. A mechanic mentioned my valves probably need to be adjusted/timed. Does this sound like a plausable cause to anyone?
Mike
Old Apr 18, 2006 | 03:57 PM
NJcoupe's Avatar
If its a ticking noise, yes.
If not, seek help.
But as far as I know/ Witnessed, all DOHC VTEC B-series do have some valve noise.
Old Apr 18, 2006 | 04:47 PM
Default Re: (dxcoupe.)
this is loud valve noise, seems too loud to be normal
Old Apr 18, 2006 | 04:56 PM
CRISIS's Avatar
Default Re: (mikeunreal2)
Get under your car and have someone rev it. you don't necessarily have to be under it. get beside the left front tire and listen to your oil pan. if you hear it loud you may have a bad rod bearing/main bearing. good luck. i'm in the same situation.
Old Apr 18, 2006 | 08:17 PM
Default Re: (CRISIS)
the reason i think its my valves that need to be adjusted/timed is beacuse it also idles rough. i would imagine is my valves were out of time this would also be affected, along with the overall performance..
Old Apr 18, 2006 | 08:26 PM
b18ek670's Avatar
sounds like you need to have your valve clearances adjusted. if its idling rough, you may also have your cam timing off a little. get your clearances adjusted first though, if it fixes it, youre good, if not, then check your cam timing.
Old Apr 18, 2006 | 08:28 PM
b18ek670's Avatar
Default Re: (b18ek670)
by the way, how is that kenji p06? i am considering getting one from him also? any problems dealing with him?
sorry its off topic.
Old Apr 19, 2006 | 03:57 AM
great guy, great product, great customer service. i take that back, amazing customer service
Old Apr 19, 2006 | 04:43 AM
stackz's Avatar
at the jetties fishin'
Community Builder
you still have a belt on your a/c compressor?? if so that tinkling/crackling noise is most probably the compressor clutch. Generally when they go bad, the front hub of the clutch just breaks off and dangles in front and just sorta slaps around against the spinning pulley...
Old Apr 21, 2006 | 10:15 PM
Default Re: (stackz)
im not sure, where should i look to see if the belt is still on that? i dont have ac, so mabye...
TORTUGA
Feb 28, 2013 08:55 PM
jaredvabeach
Apr 27, 2008 04:30 PM
85civic
Aug 31, 2004 07:22 AM
SIRBUSH
Oct 31, 2002 09:43 PM
BryanS
Sep 25, 2001 10:46 AM
