Car wont idle below 3000... Help me!
Old Apr 18, 2006 | 03:41 PM
MR_EJ8's Avatar
Default Car wont idle below 3000... Help me!
just as the title says...i cant get my car to idle below 3000rpm's. Its an LS/Vtec with a gsr head, stock gsr intake manifold with the secondaries removed and an h23 throttle body. Anyone have any ideas???
Old Apr 18, 2006 | 04:23 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Car wont idle below 3000... Help me! (sohc_sol)
Vacuum leak. Did this setup ever idle properly or is this a new problem?
Old Apr 18, 2006 | 04:41 PM
2000GSR2432's Avatar
check your throttle cable, on top of the bracket, it might be stuck or too tight.
Old Apr 18, 2006 | 07:20 PM
MR_EJ8's Avatar
Default Re: Car wont idle below 3000... Help me! (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Vacuum leak. Did this setup ever idle properly or is this a new problem?</TD></TR></TABLE>
I checked every vac line on the car, i even hooked up a vac. gauge and it read steady at 20hg. vac... i also tried 2 different idle speed motors, and checked the throttle cable to make sure it wasnt stuck open or anything...it still idles at 3 grand.
Old Apr 18, 2006 | 07:24 PM
icemangsr2's Avatar
maybe it's not a line. maybe something else is loose. i know my car idled like crap b/c the IM was loose.
Old Apr 18, 2006 | 07:50 PM
94_DC4's Avatar
check the fast idle valve on the manifold. I had the same problem with my ls/vtec. Should take about 15 min. to check. All u need is a 10mm socket and a ratchet. with a flat head screw driver turn clockwise until u cant any more.
Old Apr 18, 2006 | 09:06 PM
MR_EJ8's Avatar
Default Re: Car wont idle below 3000... Help me! (oemjdmdc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oemjdmdc &raquo;</TD></TR><TR><TD CLASS="quote">check the fast idle valve on the manifold. I had the same problem with my ls/vtec. Should take about 15 min. to check. All u need is a 10mm socket and a ratchet. with a flat head screw driver turn clockwise until u cant any more.</TD></TR></TABLE>
ive already tried 2 different ones...
Old Apr 18, 2006 | 10:17 PM
projectTeG's Avatar
leaky gasket.
Old Apr 18, 2006 | 10:52 PM
MR_EJ8's Avatar
Default Re: (projectTeG)
i think we are gonna rip the intake mani off tomorrow and start from ground zero and replace every vac. line we can find and make sure everything is sealed up tight.
Old Apr 19, 2006 | 04:01 AM
Dogginator's Avatar
Daisy... Daisy...
Start the car and block the throttle body with your hand. If it still runs, there is a vacuum leak somewhere.
Old Apr 19, 2006 | 04:18 AM
petergriffen's Avatar
clean the iacv on the back of the intake manifold
Supp Dude1
10
Sep 17, 2013 12:21 PM
Tiffany_94DOHC
10
Apr 8, 2006 12:47 AM
kb158
18
Jul 30, 2004 02:43 PM
headhunter
Aug 18, 2003 08:14 PM
wu tang
Jul 25, 2003 11:58 PM
