lowering springs
most likely u'll need a camber kit for anything that drops below 1.5". so the answer is YES!!!
Yes, have a 97 with sport, and yes, but don't bother buying the rear kit since it's just washers. The fronts are needed and be sure to get the bushings. The normal kit will be fine, but will be maxed out with still soem negative cambe. The extreme kit will be better if you want perfect camber.
madcrossover
Oct 19, 2004 10:05 AM
