oil almost quart low?
i went to go change my oil today and i checked it before i changed it.. it was about a quart low, and it was dirty ofcourse.. the oil was roughly 3200 miles old.. when i took the filter off it was alot heavier then the new one.. defective fram filter?
Note: dont think its my valve seals because im not blowin smoke out of my exhaust, searched the whole motor over, no leaks anywhere. motors at about 98,000 miles.. D16y8, all stock internals, just the ocasional bolt ons
Common thing with Honda cars. Seems like they burn about a quart in between changes. All of mine seemed to do it. I just topped them off about every 1500 miles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crawdad »</TD></TR><TR><TD CLASS="quote">Common thing with Honda cars. Seems like they burn about a quart in between changes. All of mine seemed to do it. I just topped them off about every 1500 miles.</TD></TR></TABLE>
yeah.. the funny thing is though this is the first time its done it.. maybe cause im near the 100,000 mile mark.
Common thing with almost all cars. Cars burn oil after a while. A quart between changes is considered normal.
Now you should be alarmed if up to this day it never burned oil. Or if your next oil change is substantially more. However, if it is constant don't worry about it. Just my 0.02
Cheers.
Cheers.
iono "old man neri" -- none of my cars ever burned a whole court in the duration of 3k miles...oh well, guess I'll have to check it now if I hear that all hondas do that...woooooord...thx for the tip I guess at OP
Average car burns 1qt every 1,000mi. Oil Filter is heavier cause its wet and has debris inside it. I would go with a factory filter instead of a Fram
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by badcompany_2205 »</TD></TR><TR><TD CLASS="quote">what are the benefits of the stock oil filter???
Search "filter". You will get a ton of arguments and thoughts on the matter. Many multiple page threads on the subject
</TD></TR></TABLE>Search "filter". You will get a ton of arguments and thoughts on the matter. Many multiple page threads on the subject
Telecatster
18
Dec 30, 2012 10:59 AM
