JRSC B18C5 with ITR pistons and LS Rods?
Old Apr 18, 2006 | 11:58 AM
Renegade's Avatar
Default JRSC B18C5 with ITR pistons and LS Rods?
what are the benefits and or are there any downfalls to running ITR pistons with LS rods on an JRSC ITR?
If I understand correctly, which i may not, the LS rods woudl yield more torque, correct?
thanks
Old Apr 18, 2006 | 12:12 PM
Importordomestic's Avatar
Default Re: JRSC B18C5 with ITR pistons and LS Rods? (Renegade)
swapping out the rods wont do you much good withought the LS crankshaft. Honestly you will be better with leaving the b18c alone and bolting the JRSC to it.
What you are describing is simular to a LS/Vtec, i personally would just keep the b18c5 for reliability and power.
Old Apr 19, 2006 | 06:57 AM
Renegade's Avatar
Default Re: JRSC B18C5 with ITR pistons and LS Rods? (Importordomestic)
the charger has been in, just gettinG to the point to rebuild the block with forged pistons and rods as well as gapless rings. Just wanted to get a feel for the changes.
The ITR crank is counterweighed and balanced, what if the LS crank is sent out for the same?
I guess what I am asking all forged internals with the LS cranck machine balanced etc....
I had seen some post explaining the difference between the ITR crank and LS, but I could not find them again, so that is all I vaguely remember about them.
Modified by Renegade at 7:32 PM 4/19/2006
turbodcxbro
25
Jan 7, 2010 07:30 AM
drewlee
Jun 19, 2003 01:37 AM
DOHCon15s
Apr 13, 2003 08:58 PM
