Over torqued oil t in block and block cracked
Old Apr 18, 2006 | 10:28 AM
em1 Ziggy's Avatar
Default Over torqued oil t in block and block cracked
looks something like this
how can i fix this???? u think jb weld will work??? Right when i got my oil t from tuner toys i installed this and this is what happened... dammit! any know have suggestions where i can mount my oil feed line and stock oil pressure.. other then the block
Old Apr 18, 2006 | 10:29 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: Over torqued oil t in block and block cracked (em1 Ziggy)
Looks like you've got some fun ahead of you... free bump
Old Apr 18, 2006 | 10:31 AM
Schister66's Avatar
Man U FTW
get one of those oil sandwich things that go between the oil filter and the block.....also, JB Weld the crap out of that crack so that it doesn't leak.
Finland's Avatar
JB weld is not the answer. I'd have someone tig that back together. Might have to pull the block and take it to a welder.
Old Apr 18, 2006 | 10:33 AM
em1 Ziggy's Avatar
Default Re: (Mr. Helsinki)
any one have other ways i don't feel like taking my block out..... where can i get htis sandwich?
Old Apr 18, 2006 | 11:02 AM
HT Chaplain's Avatar
Loved
http://www.streetrays.com/cata...age/5
this is where i bought mine greeat service and price hes a HT sponsor
Old Apr 18, 2006 | 11:16 AM
vaporboy12's Avatar
Default Re: Over torqued oil t in block and block cracked (HT Chaplin)
get a 1/8 ntp plug thread it in so some of the thread are in the block then jb weld the expletive out of it is the only way without pulling the block
Old Apr 18, 2006 | 11:21 AM
Schister66's Avatar
Man U FTW
that's 2 for JB weld....
Old Apr 18, 2006 | 11:43 AM
SL0WEGG's Avatar
Default Re: (Schister66)
how the hell did you overtorque that?
Old Apr 18, 2006 | 11:59 AM
Mr. Vapor's Avatar
Default Re: (boostedej1)
eeek....
put the fitting back in and have it Tigged, thats my vote. dont expletive around with JB weld.
imagine this:
you're cruising along, full 3rd gear pull at redline and your "JB weld" decides to let go....there goes all your oil and your motor
Old Apr 18, 2006 | 12:09 PM
Boosted Chemist's Avatar
Default Re: (Mr. Vapor)
i would tig that shut and use the extra ports on the sandwich for hte stock oil pressure sending unit.
Old Apr 18, 2006 | 12:16 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (Boosted Chemist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist &raquo;</TD></TR><TR><TD CLASS="quote">i would tig that shut and use the extra ports on the sandwich for hte stock oil pressure sending unit.</TD></TR></TABLE>
gets my vote
Old Apr 18, 2006 | 12:32 PM
nerdsports's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist &raquo;</TD></TR><TR><TD CLASS="quote">i would JB weld that **** and use the extra ports on the sandwich for the stock oil pressure sending unit.</TD></TR></TABLE>
for me.
Old Apr 18, 2006 | 12:55 PM
delacampos's Avatar
Default Re: (nerdsports)
this has happened to me and JB weld did not work. my block did not crack no where near as bad as yours. it was a hairline fracture. i used jb weld and not only did the block look like ****, it continued to leak. not a lot but enough for me to notice it and i could not live with it.
Old Apr 18, 2006 | 01:11 PM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Me &raquo;</TD></TR><TR><TD CLASS="quote">i would JB WELD that shut and use the extra ports on the sandwich for hte stock oil pressure sending unit.</TD></TR></TABLE>
Mugencrxsir1's Avatar
Default Re: (delacampos)
Greddy, and Golden eagle both make nice sandwich plates. You can always buy a no name brand off ebay.
Old Apr 18, 2006 | 01:31 PM
I Have an STD's Avatar
wrenchin'
Default Re: (Mugencrxsir1)
1st off, lots of brake clean is your friend, you need to make that area REALLY clean before you try to jbweld it. put the piece back on that broke off, and put a 1/8 npt plug in the hole. THEN jb weld the living f uck out of it. just do a bunch of thin coats, and let the JB dry between each coat. it might take a couple days to get it to where you're confident that u can start it, but it WILL work if you take the time to do it right (can anything REALLY be done right with jbweld?) and if that doesnt work, you can always take out the motor and get it tigged. might as well try the JB 1st.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Vapor &raquo;</TD></TR><TR><TD CLASS="quote">eeek....
imagine this:
you're cruising along, full 3rd gear pull at redline and your "JB weld" decides to let go....there goes all your oil and your motor </TD></TR></TABLE>
and you shut up, you have jbweld on your oil pan
Old Apr 18, 2006 | 01:42 PM
CRXdan's Avatar
Ouch
Old Apr 18, 2006 | 01:58 PM
em1 Ziggy's Avatar
Default Re: (CRXdan)
alright i just bought brake cleaner and a sandwich from camp1320. the guy from camp told me to just use KBweld and a plug he supplied for me... Hope it works.. thank you guys shall let you know if it leaks
Old Apr 18, 2006 | 02:01 PM
Turbo-charged's Avatar
i would never even consider jb welding something like that.
Old Apr 18, 2006 | 02:06 PM
em1 Ziggy's Avatar
Default Re: (Turbo-charged)
is there anything else thats better then the jbweld technic without having to pull the block out to get it welded?
Old Apr 18, 2006 | 02:17 PM
5STAR3's Avatar
Default Re: (em1 Ziggy)
welding it would be the correct way, imo.
either way, jbweld or normal weding, i would want the area super clean. so it would be much easier to just take the block out and do it right.
if there are enough threads letf to use a plug that would be fine.
Old Apr 18, 2006 | 02:28 PM
btotherizzle's Avatar
if you took the intake mani off could you weld it from above while the motor is still installed? That's sucks ***, easy on the aluminum block it's weak as expletive.
Old Apr 18, 2006 | 02:38 PM
SOHC_MShue's Avatar
Default Re: (btotherizzle)
Personally I would take the easy way out and JB Weld it...not saying that is the best way though
Old Apr 18, 2006 | 02:53 PM
em1 Ziggy's Avatar
Default Re: (SOHC_MShue)
well heres the kbweld im probably hold off on this i know it looks ugly but my im having a hard time putting it on with the lack of space... u guys think this will hold until i get a good weld or should i stack some more jb on it?
